Problems with Eagle H-Beams in a 93 z6???
Old Apr 14, 2006 | 09:09 PM
fishnfst's Avatar
Default Problems with Eagle H-Beams in a 93 z6???
Anyone have clearance problems with the Eagle Hbeams in a z6? I got my motor back from the machine shop and went to install it.. I put piston 1-4 in and then tried to turn the crankshaft and it binds... It looks like the webbing and rod bolt is hitting the cylinder walls?
Has anyone else had this problem? What did you do to alleviate the problem? How much did you have to clearance the cylinder walls? Did you have any problems getting too close to the coolant passage?
Should I just get different rods? I can't believe they don't fit...
Old Apr 14, 2006 | 09:13 PM
Quad-Damage's Avatar
Default Re: Problems with Eagle H-Beams in a 93 z6??? (fishnfst)
Noach the block a bit
Txdragon
Engine Machining & Assembly
May 2, 2019 03:20 AM
90crxdriver
Feb 15, 2009 07:41 PM
UserX826
19
Jan 22, 2009 05:50 PM
1boostedcivic
May 17, 2005 11:37 PM
ELSpool
Sep 5, 2003 03:59 PM
