B18a1 swap please help
Old Apr 14, 2006 | 08:43 PM
pchris52's Avatar
Default B18a1 swap please help
OK i swapped a b18a into my 93 civic had it all running problem wrong it wouldn't redline it wrap it self out at 5000 grand everytime timing is dead on i'm 100% sure on this so i dont want to hear a timing issue, but worse yet i was drivin home from college an it has died an now i cant revive it. here is of a list of things done
Motor
compression test was great
new seals an head gasket was done
new starter
new dizzy
new plugs an wires
new 255 cc injectors from venom
new fuel regulator an filter
fuel pump running fine
no check engine
main relay is clicking after key is turn an fuel pump has kicked on
car is gettin spark in every cylinder
map senor tps sensor are getting voltage an have the correct ohms
injector have the correct ohms
same as the voltage comming through the harness
dizzy was stabbed correctly
but the egine just turns jerking like somthing wont let it be freed up motor is turning freely i just dont understand why it wont start spark plus fuel should be somthin? HELP PLEASE!
jeryhawj
Jul 13, 2011 09:44 AM
kuNGFu pANDA2o9
Jun 26, 2009 09:00 AM
accord-h22
Feb 13, 2007 04:45 PM
pchris52
Apr 17, 2006 04:00 PM
