Which Throttle Cable/Bracket to use with AEBS GSR I.M.?
Old Apr 12, 2006 | 05:47 PM
THE GAME IS THICK's Avatar
Default Which Throttle Cable/Bracket to use with AEBS GSR I.M.?
I will be swapping in a B18C1 with an AEBS Intake Manifold in my del sol shortly but I was wondering what throttle cable to use and bracket?
Old Apr 12, 2006 | 09:29 PM
Default Re: Which Throttle Cable/Bracket to use with AEBS GSR I.M.? (THE GAME IS THICK)
bump
Old Apr 12, 2006 | 11:21 PM
saccord's Avatar
well your in luck, my friend just did the exact same setup in his del sol. he used the throttle cable bracket from a 94-95 gsr, problem is, when you close the hood or move the cable around it messes with the idle. they sell aftermarket throttle cable brackets, thats your best bet, it will mount on the two holes on the third runner on the manifold, oh yea, when he put that manifold on it actually made his car slower. tooooo much air, not enough fuel so think about some kind of fuel management after your done, or you will not be impressed
Old Apr 13, 2006 | 10:43 AM
rollydc69's Avatar
Default Re: Which Throttle Cable/Bracket to use with AEBS GSR I.M.? (saccord)
ITR throttle bracket will work.
Old Apr 13, 2006 | 10:34 PM
Default Re: Which Throttle Cable/Bracket to use with AEBS GSR I.M.? (rollydc69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saccord &raquo;</TD></TR><TR><TD CLASS="quote">well your in luck, my friend just did the exact same setup in his del sol. he used the throttle cable bracket from a 94-95 gsr, problem is, when you close the hood or move the cable around it messes with the idle. they sell aftermarket throttle cable brackets, thats your best bet, it will mount on the two holes on the third runner on the manifold, oh yea, when he put that manifold on it actually made his car slower. tooooo much air, not enough fuel so think about some kind of fuel management after your done, or you will not be impressed</TD></TR></TABLE>
I have a FPR and Hondata. Also Planning on doing a direct port since I heard that this manifold already has holes for it on the under side. Is this correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollydc69 &raquo;</TD></TR><TR><TD CLASS="quote">ITR throttle bracket will work. </TD></TR></TABLE>
should I get that cable too or can I use my stock del sol one? Im thinking that I still can use it. I also have a LS Throttle bracket will that work just as good as an ITR?
Old Apr 14, 2006 | 08:36 PM
rollydc69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GAME IS THICK &raquo;</TD></TR><TR><TD CLASS="quote">
should I get that cable too or can I use my stock del sol one? Im thinking that I still can use it. I also have a LS Throttle bracket will that work just as good as an ITR?</TD></TR></TABLE>
I dont know about LS, I have a AEBS manifold on my hatch and i only used the Type r bracket.
Is your LS look like this???
Modified by rollydc69 at 5:53 AM 4/15/2006
Old Apr 14, 2006 | 09:38 PM
Ivan's Avatar
senior gold member
I'm using an ls throttle cable bracket and cable on my gsr motor.
GSR-TRBO-DA
Jan 13, 2008 04:30 PM
devney
Aug 3, 2007 08:39 PM
kcjohnnyboy
Sep 21, 2006 12:01 AM
JDM00SI
Jan 22, 2006 02:06 PM
gsr98teg
Feb 6, 2004 02:06 PM
