shift linkage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MajorPayne »</TD></TR><TR><TD CLASS="quote">if i remember correctly, they are interchangeable...someone correct me if im wrong though</TD></TR></TABLE>
They are. GSR linkage will work fine in your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">i thought the EG needed the del sol or 2000 si linkage and the teg linkage was longer or shorter???</TD></TR></TABLE>
well a del sol is an EG chassis, so it would be the same, but they are interchangeable for the si's and gsr's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">what about regular teg linkage??? im not talking gsr, just ls,gs,rs,etc... i was told they wont work on an eg</TD></TR></TABLE>
They are all the same regardless of trim level, and will work. They will require a spacer where the shifter bolts on though, if you are using a Civic shifter instead of an Integra shifter.
turbodelsolb16a2
Jul 28, 2013 11:37 PM
