shift linkage?
shift linkage?
i am swapping a GSR motor into my civic, with a GSr tranny, i dont have the shift linkage though, will gsr linkage work or only SI?
Re: shift linkage? (MajorPayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MajorPayne »</TD></TR><TR><TD CLASS="quote">if i remember correctly, they are interchangeable...someone correct me if im wrong though</TD></TR></TABLE>
They are. GSR linkage will work fine in your car.
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">i thought the EG needed the del sol or 2000 si linkage and the teg linkage was longer or shorter???</TD></TR></TABLE>
well a del sol is an EG chassis, so it would be the same, but they are interchangeable for the si's and gsr's
what about regular teg linkage??? im not talking gsr, just ls,gs,rs,etc... i was told they wont work on an eg, and that del sol B16 linkage worked as well as 00 si linkage.
be professional
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">what about regular teg linkage??? im not talking gsr, just ls,gs,rs,etc... i was told they wont work on an eg</TD></TR></TABLE>
They are all the same regardless of trim level, and will work. They will require a spacer where the shifter bolts on though, if you are using a Civic shifter instead of an Integra shifter.
turbodelsolb16a2
07-28-2013 11:37 PM
