b16 smoke
Old Apr 14, 2006 | 10:42 AM
wullie_vtec's Avatar
Default b16 smoke
my b16 has a lot of smoke when idling which looks white but it clears up when i drive off but when i hit the vtec there is blue and black smoke also the car doesnt idle properly it cuts out when cold but hunts when warm ive changed valve stem oil seals and big ends is this my piston rings and is there any way to check them its going through a bit of oil ive been told this is normal if its drove hard is this right
Old Apr 14, 2006 | 03:46 PM
charlee's Avatar
Default Re: b16 smoke (wullie_vtec)
did you just recently get this engine?when i got my h22 of a engine importer it was smoking like a motha, making me go back and yell at the person who sold it to me. he just said run it for like a week or two and it will clear up..and it did.no smoke at all.but if you already got time with this engine it could be your rings
Old Apr 15, 2006 | 12:26 AM
Default Re: b16 smoke (charlee ricer)
ive had it a while now. i was out in it this morning and there was the usual idling problem but there was like a rumbling noise when accelerating but it quietens down when it warms up its done this for a while now but it went away for about 2 weeks and its back now any ideas ive been told this could be my rings but i didnt bother as it stopped any ideas
Old Apr 15, 2006 | 03:14 PM
charlee's Avatar
i know this might feel like **** buit the fact that is throwing out blue smoke is because youre burning oil. black smoke is from a ritch mixture.if the smoke quits coming out when idling. is just your valve seals that are bad.dont stress out and have your compression checked.if its normal then you dont need a new block. could be that you just need the heads fixed.or buy new ones and trade those in to cut the price down. idling bad could just be because you are gettin oil in your chamber. here try this. get a can of fuel injection cleaner.unhook your air intake from the throtle body . start the engine and spray it into the intake manifold.dont let the engine die.rev it up by the intake at the same time you spray it in there.spray so much in the intake that if you have the throtle open like 1/4 the the ingine still sounds like if it was idling.(rough idling of course).if you see that the car is throwing a lot of blue and white smoke from the exhoust.that means youre cleaning the **** out of it. after that shut off the engine.open the throtle body all the way and you are going to notice is gonna be black as hell in there still.spray the fuel injection cleaner all around inside the plenum and notice all the black tar come off.try to start your engine.it will take a while since it will be flooded from al that crap that just came off your inner walls of the intake manifold.this might help your idling problem by cleaning all the sensors an the mainifold. i hope this woks for you man. rmember dont loose hope. it could just be a simper problem. but try it. it really worked for me
honshu
Jun 9, 2012 10:36 AM
prettylew
45
Dec 16, 2007 06:48 PM
supabang
Apr 17, 2007 02:26 PM
getzy3
Apr 18, 2005 03:41 PM
Psixas
Jul 15, 2003 08:44 AM
