B16 Smoking??
Old Apr 18, 2005 | 02:02 PM
getzy3's Avatar
Default B16 Smoking??
My friend messed up a valve while spraying his B16 and had all new valves put in that were a little bigger that stock. He also had the whole motor tore down and put new rings in. Now when he first starts it up it smokes a good bit until he starts driving. When he gets on it it hard it smokes again and sometimes makes a popping sound when he shifts like backfiring, im thinking it is detonating but i dont know for sure. What could be the problem for the smoking and popping?? The B16 is all stock except, I/H/E and isnt using oil.
Old Apr 18, 2005 | 02:39 PM
notstock93's Avatar
Default Re: B16 Smoking?? (getzy3)
What color is the smoke? Im guessing its white if hes not burning oil.
Check the headgasket.
Old Apr 18, 2005 | 03:08 PM
getzy3's Avatar
Default Re: B16 Smoking?? (notstock93)
its white, not blue. The head gasket is brand new from when they put the motor back together. Could it stille be the problem?? Some said it was running lean, anyh truth to this??
Old Apr 18, 2005 | 03:41 PM
notstock93's Avatar
white smoke is burning coolant. You can smell the exhaust and it should smell slightly sweet (anti-freeze) if it is indeed coolant
It MAY be the innards of the new cat burning off and causing smoke. I don't know, Ive never replaced my cat so I have no first hand experience with that.
Check your radiator for oil, check your oil for coolant (will look like peanut-butter) and see what you find.
cars101
20
May 6, 2007 02:38 PM
kixcrx
Jan 10, 2007 01:46 PM
mikeunreal
Nov 23, 2005 06:31 AM
ImportPower13
Apr 23, 2005 12:36 PM
1990civicsi
Aug 8, 2004 06:33 PM
