Got SMOKE ?
Old Apr 17, 2007 | 03:27 AM
supabang's Avatar
Default Got SMOKE ?
I just recently been getting whitish smoke out of my tail pipe. I'm almost 100% positive its oil burning but i have no clue why. Its not smoking constantly but only every now and then. sometimes a little and sometimes enough to make the car behind me do a ninja dissapearing trick. I checked the turbo for play and theres none. all i can find is plug #4 was wet and all the others were dry. Anyone got any ideas? Is this a major problem? i can still drive and i made a couple of pulls with full power and no problems (besides for the smoke that is) Also at high rpms you would think it would smoke more, but seems to be less. I can idle with no smoke and out of no where it will start up. I'm lost. Maybe a bad piston ring? any help would be appreciated.
Old Apr 17, 2007 | 04:09 AM
Runnerdown's Avatar
Default Re: Got SMOKE ? (supabang)
Probably smoking after decelerating right? Or idling for a bit and then a stab of the gas? Sounds like a typical honda ring problem to me. carbon buildup usually hold the low tension oil rings in their groove, and they cannot expand or move freely. High vacuum in the cylinder pulls some oil up past. I have done numerous quick and dirty re-rings before, but its best to just pull the whole thing and freshen it up.
I had a friend with a great running gsr, one day it started smoking badly. We pulled it apart and low and behold the number 3 cylinder had the rings stuck. hottest running cylinder = most likey to have deposit buildup.
Old Apr 17, 2007 | 04:14 AM
supabang's Avatar
Default Re: Got SMOKE ? (Runnerdown)
hmm... so you're saying i should just get new rings? wish there was another way around this. any idea what the average cost on a job like this? Also is there anything else i can look at or check for ?
Old Apr 17, 2007 | 10:06 AM
supabang's Avatar
??? any ideas? anyone ?
Old Apr 17, 2007 | 01:11 PM
sharkytm's Avatar
you could try a dose of Seafoam, but if the rings are really stuck, it might not work. Its cheap, and can't hurt.
Old Apr 17, 2007 | 02:26 PM
supabang's Avatar
Default Re: (sharkytm)
thanks for the input. haven't had much help. but i have no idea where to get Seafoam from. Never actually herd of the product. maybe its time for new pistons and sleeves ?????
IMPORTant Si
Jan 27, 2010 02:05 PM
prettylew
45
Dec 16, 2007 06:48 PM
G-Phi
May 17, 2006 07:38 PM
gsr355
Jul 24, 2001 11:00 AM
gsr355
Jul 22, 2001 12:45 AM
