My O2 Sensor disappeared?? o.o
I've got a 93 EXR and apparently for EX/EXR models the heated O2 sensor should reside in the exhaust manifold, right?
... Mine's not there ^.^; (So it's probably under the car as it is with the other trim selections. Haven't had a chance to jack it up as of yet.)
I'm a bit confused... ^.^;
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ParoXoN »</TD></TR><TR><TD CLASS="quote">Ahh, thanks ^.^
If it faces up -- towards the engine -- how easy is it to get out?</TD></TR></TABLE>
piece of cake,, but you got to raise the car and remove it from underneath,, it is located on frt exh pipe.. before cat.. you need a 22 mm wrench ,,,
Perfect, have to get the thing up to check out the front-passenger ABS sensor anyway.
Do I need any sort of a special socket to work around the wiring harness?
Thx for the info ^.^
gulftiresinc
Sep 23, 2004 04:51 AM
