600whp!!!
Old Apr 13, 2006 | 10:01 AM
icebergli's Avatar
Default 600whp!!!
Anyone think a built h22 with gt35r is capable of hitting 600?
Old Apr 13, 2006 | 10:02 AM
adictionbass's Avatar
Default Re: 600whp!!! (icebergli)
yes
Old Apr 13, 2006 | 10:19 AM
99B16Si's Avatar
i dont think its ever been done but you could be the first
Old Apr 13, 2006 | 10:21 AM
flip1199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icebergli &raquo;</TD></TR><TR><TD CLASS="quote">Anyone think a built h22 with gt35r is capable of hitting 600? </TD></TR></TABLE>
nope, only 1.6l b16's can do that....
Old Apr 13, 2006 | 10:25 AM
ChrisRicketts's Avatar
Default Re: 600whp!!! (flip1199)
if you could you'd really be maxing that turbo out.........you'd be way out of its efficiency range. if you want to make 600whp i'd use a different turbo, but i think it's probably possible to answer your question.
Old Apr 13, 2006 | 10:59 AM
boosted92's Avatar
Default Re: 600whp!!! (ChrisRicketts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">if you could you'd really be maxing that turbo out.........you'd be way out of its efficiency range. if you want to make 600whp i'd use a different turbo, but i think it's probably possible to answer your question.</TD></TR></TABLE>
The GT35R's will make about ~675 WHP absolutely maxing them out. They're a perfect choice for a 600 WHP setup. I don't know why everyone wants to go overkill and size up so you can add an extra 300 WHP down the road, "just in case".
Old Apr 13, 2006 | 11:12 AM
Dunc's Avatar
BCICAN
Default Re: 600whp!!! (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
The GT35R's will make about ~675 WHP absolutely maxing them out. They're a perfect choice for a 600 WHP setup. I don't know why everyone wants to go overkill and size up so you can add an extra 300 WHP down the road, "just in case".</TD></TR></TABLE>
"Just in case" is the American way. We just stock up on useless crap and overkill everything.
Old Apr 13, 2006 | 11:16 AM
beerbongskickass's Avatar
Yeah if you pay somebody that knows what they are doing to build it for you, but if you have to ask I doubt you could do it on your own.
Old Apr 13, 2006 | 11:23 AM
BoostR41's Avatar
Default Re: 600whp!!! (beerbongskickass)
local H22 in a accord wagon did 654whp on a 35R with .82 hotside. it is way capable
Old Apr 13, 2006 | 12:16 PM
icebergli's Avatar
Default Re: 600whp!!! (BoostR41)
My turbo has a .82 hotside. So we'll see.....maybe i'll get similar numbers hopefully?
Old Apr 13, 2006 | 12:17 PM
h22 civic's Avatar
if you search my name for my setup last year i made 605 @27 psi on a gt35 with h22 and it was def . running out of breath but i would make sure you are working with a stout bottom end and if you are planning on running a setup like this at the track with slicks def invest in good axels ,clutch, and i would invest in a external oil pump system IMO
Old Apr 13, 2006 | 12:29 PM
icebergli's Avatar
Default Re: 600whp!!! (h22 civic)
DRT tuned your car?
Old Apr 13, 2006 | 01:07 PM
i'm just saying that if you want to make 600whp, why get a turbo that is rated at 600whp?.......instead get one that's rated at 750-800whp, that way you aren't kicking it's *** every time you push the gas.
that's like saying, i'm gonna bungee jump from a 100 foot bridge, and give myself enough cord to drop about 100ft. down. you need to give the turbo at least a little slack.
ok, now hold on a sec while i pop open my hater umbrella so i don't get rained on by the dyno queens.
Old Apr 13, 2006 | 01:33 PM
h22 civic's Avatar
they used to, if ya know ralphy he should still have teh program of my car at 20psi it made low 500s (525or 535) with a very sufficient tune i hade zero probs with it
Old Apr 15, 2006 | 01:27 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">i'm just saying that if you want to make 600whp, why get a turbo that is rated at 600whp?.......instead get one that's rated at 750-800whp, that way you aren't kicking it's *** every time you push the gas.
ok, now hold on a sec while i pop open my hater umbrella so i don't get rained on by the dyno queens. </TD></TR></TABLE>
Why would you get rained on by dyno queens? They would be saying "Booyah, run a PT76 so you have 900 WHP potential with zero powerband!"
Just because the 35R is "rated" at about 600 WHP doesn't mean that's the max it will make, and buying a turbo that will make 750 or 800 WHP when you're shooting for 600 is a poor choice. It will give you more lag, make your car slower, and less fun to drive. 600 WHP from a 35R is not overspinning it, and is the perfect choice for a driveable 600 WHP. Last time I checked, I didn't run my car around on straight C16 and 28 psi all day long, so I'm not "kicking my turbos ***" every time I get on it either.
Old Apr 15, 2006 | 10:24 PM
Just because the 35R is "rated" at about 600 WHP doesn't mean that's the max it will make, and buying a turbo that will make 750 or 800 WHP when you're shooting for 600 is a poor choice. It will give you more lag, make your car slower, and less fun to drive. 600 WHP from a 35R is not overspinning it, and is the perfect choice for a driveable 600 WHP. Last time I checked, I didn't run my car around on straight C16 and 28 psi all day long, so I'm not "kicking my turbos ***" every time I get on it either.</TD></TR></TABLE>
yea......i guess that makes sense. MY BAD YO!
Old Apr 16, 2006 | 12:59 AM
bootlegcivic's Avatar
didn't jeff evans just make 650whp on a 1.8L with a gt35R??? If you have a totally built setup you should be able to...
rock out with your **** out if you're ready for race gas
Old Apr 16, 2006 | 09:20 AM
96 GSR-T's Avatar
Default Re: 600whp!!! (bootlegcivic)
Evans told me recently he has never had a 1.8L top 550whp......I know what I read so either he or I was mistaken if there is a 650who car.
He told me this when he read my thread about my build and my power goals.
Update* Sorry....he was refering to a 60-1 T3 Based turbo which I have
Old Apr 17, 2006 | 10:30 PM
you are retarded!!!!
bossm
23
Feb 13, 2008 06:01 AM
huge230
Feb 10, 2006 12:14 PM
TurboSam
Jan 28, 2004 11:02 AM
h22ah
Oct 31, 2003 12:52 PM
tonesdef
Jul 20, 2003 09:39 PM
