Side Restraint System
Old Apr 13, 2006 | 07:35 AM
rrk's Avatar
rrk
Default Side Restraint System
I have a 2000 Accord EX and the SRS (side restraint system) "idiot" light is on. Before I go spend five bazillion dollars at the dealership does anyone know if there is anything I can do to check the system? I'm not intrested in just disabling the light, especially if something is truly wrong.
Thanks,
Ryan
Old Apr 13, 2006 | 11:52 AM
Ross 2.0's Avatar
In a Junkyard near you.
There is a YELLOW two pin connector in your drivers fusebox. (the only one like it) Pull that connector down and short the pins with a paperclip. Turn the ignition on and count the blinks. The long blinks are the 10's place and the fast blinks are the ones place so 3 long and 6 short would be code 36 or 3-6. Post that code here and we can help you further.
Old Apr 14, 2006 | 12:07 PM
rrk's Avatar
rrk
Default Re: (MooGoCow3)
After ignition the light stayed on briefly, went out for a long pause, then lit for a second, went out for a second, then lit again and stayed on. I tried it twice and it did the same thing. I don't know if this means 1-1, 0-2, or 2-0. Hopefully you know.
Thanks for the help,
Ryan
zeez74
Mar 13, 2014 10:32 AM
elijah
Mar 14, 2006 09:03 AM
ultraforce77
Aug 7, 2004 10:17 AM
J T*
Feb 20, 2002 08:16 PM
