d15z1 Vtec E revvin help PleaZZ
I swaped my 89 std to a d15z1 VtecE and my car will not revv past 4,000 rpm what censors could be unplugged because the car starts up perfectly but it just want rev up higher then 4,000 rpm is it the censors or is it my computer.
I did help you (in PM),
you need to help us... what ecu, what dizzy, what instructions did u go by. You said you wired it right to me, what does that mean? Could it be wrong? let us know... what ecu jumper, yo know, things like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89eFRACER »</TD></TR><TR><TD CLASS="quote">91 si ecu,91 si dizzy and its OBDO0</TD></TR></TABLE>
I'm wondering if this is part of the problem. Running a 12valve obd1 vtec-e motor (without vtec) on an a obd0 16 valve SI ECU might freak out the ECU. The fuel maps are all different.
So... is the Check Engine Light on or not?
if it is, look at the ECU and count how many long/short blinks it is producing on the small red LED.
