axle removal help.
Old Apr 12, 2006 | 06:01 PM
djSALIX's Avatar
Default axle removal help.
ok i have a 96 gsr and i need to get the driverside axle out.
i tried and tried. then i figured i could do it if i took it apart.
Now the inner part is still attached to the halfshaft and I can't get it out.
How do I get it out?
Old Apr 12, 2006 | 07:59 PM
blkb18's Avatar
Default Re: axle removal help. (djSALIX)
the half shaft is connected by 3 bolts to the engine, if those are out then tap it out with a hammer, if it doesent come out then hit it harder with a bigger hammer, good luck.
Old Apr 12, 2006 | 08:19 PM
djSALIX's Avatar
Default Re: axle removal help. (blkb18)
i'm not trying to get the halfshaft out.
i'm trying to get the axle out.
Old Apr 12, 2006 | 08:32 PM
Ruben19's Avatar
hit the inner side of the axle with a hammer.
if not.
remove the 3 bolts that hold the halfshaft.
if you do this it will come out as a one unit.
or use a extention bar.
this is the only way
man
Old Apr 12, 2006 | 09:20 PM
blkb18's Avatar
the outer shaft has a c-clip that holds it in the halfshaft, just smack it outwards with a hammer, hit it right where it meets the halfshaft.
MIGPA26
11
Feb 20, 2010 01:17 PM
Tommy_Gunns
Apr 13, 2009 09:39 PM
EGPrelude
Jun 17, 2008 07:46 AM
huepowered
Mar 27, 2006 12:33 PM
Doogie Howser
Sep 5, 2002 06:44 PM
