Engine moving...what now?
Old Apr 11, 2006 | 05:10 PM
ComptonsF1NEST's Avatar
Default Engine moving...what now?
I have a DA and whenever i shift the motor jumps back it feels like.
THis is the thing. It did this about 1 month ago so i got brand new Innovative 75a solid mounts. at 5 psi it was fine, didnt move at all. I jumped it up to 10 psi and now it jumps whenever i let off the gas w/o the clutch, i mean it jumps badly, out of boost it is worse at low rpms. Could the bolts have come loose? is it my clutch slipping? Those are the only 2 things i can thing of
Old Apr 11, 2006 | 05:15 PM
Micha's Avatar
FAILWGN
Default Re: Engine moving...what now? (ComptonsF1NEST)
You replaced all motor and tranny mounts?
Old Apr 11, 2006 | 05:18 PM
Default Re: Engine moving...what now? (Blu99teg)
yea 75a for the pass, rear, trans mount, 60a for the crossmember mount.
Old Apr 11, 2006 | 05:21 PM
SlamminS85's Avatar
could have broken them, check it out, i ripped a mount in half when i hit a huge pothole and basically pushed my tranny way up and ripped the mount
Old Apr 11, 2006 | 05:24 PM
yea actually it started on a ******* terrible bumpy road
Old Apr 12, 2006 | 09:24 PM
Default Re: (ComptonsF1NEST)
looked at all of my mounts, revved the motor, it didnt move while in neutral. What else could cause this?
Old Apr 12, 2006 | 09:28 PM
jdm_bones's Avatar
It does sound like you may have a bad mount. Check all of them again, and check that they aren't lose...You may also want to add some engine dampers, if you are going threw engine mounts like that...
I CRX I
12
Jun 18, 2010 05:56 AM
JaguarS4R
Honda Civic (2001 - 2005)
Feb 20, 2010 06:00 AM
Dirtyb16
Jan 24, 2009 01:56 PM
b16a2EBP
Mar 20, 2006 11:55 PM
ridestrt
Jul 29, 2003 08:05 AM
