Lift the car and supporting on jack stands.
Old Apr 12, 2006 | 11:17 AM
exies's Avatar
Default Lift the car and supporting on jack stands.
This is probably not the place to post this, but since I have a Type R, I thought it would be okay.
I was wonder where are the point to jack up the car from the front and rear to place onto the jack stands. I assume the tow hook is the space spot for the rear (but I'm not sure), but where is it on the front?
I need to take off the spark plug anti fouler off my cat. I think the linkage cut the wire, cause it was rubbing when I put it on.
Old Apr 12, 2006 | 11:22 AM
nightrider's Avatar
Default Re: Lift the car and supporting on jack stands. (exies)
look in your owner's manual for clarification, but it's under the radiator core support in the front. it seems obvious with the crown where the jack will support the weight of car. for jack stands, the jacking point on either side right behind the mud guards.
Old Apr 12, 2006 | 11:23 AM
Eva01's Avatar
Default Re: Lift the car and supporting on jack stands. (nightrider)
Tow hook in the rear is the correct jacking point for the back.
Old Apr 12, 2006 | 11:51 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Lift the car and supporting on jack stands. (Eva01)
You have 4 on the car: 2 on each side, rear tow hook, and the front core support(there is a place to jack).
Oh yea, I see where your from, pm me!
Modified by walker111 at 4:12 PM 4/12/2006
Junior1023
Oct 30, 2013 11:33 AM
project504
Sep 22, 2009 12:25 PM
suckmypistons
Aug 28, 2006 12:22 AM
gamby
12
Mar 30, 2004 02:09 PM
BigZ88
Jul 24, 2002 12:23 PM
