stuters when i hit 3500 rpm help
Old Apr 11, 2006 | 08:02 PM
only1gcue's Avatar
Default stuters when i hit 3500 rpm help
I need help when I step on the gas and hit 3500 rpms iut starts stutering on every gear like if it doesn't have any gas going into it. I have a fuel pressure regulator set at 50 psi i have checked all the hoses and there is no leak. i also have a walbro 255 fuel pump in it. all the sensors are pluged in. Its a new swap. Dam its has given me so many problems. If any one can help i would appreciate it thanks
Old Apr 11, 2006 | 08:50 PM
yellowrexsi's Avatar
Default Re: stuters when i hit 3500 rpm help (only1gcue)
Is that 50 psi at idle. If so, I think its to high. Should be around 35 psi
Old Apr 12, 2006 | 09:33 PM
only1gcue's Avatar
Default Re: stuters when i hit 3500 rpm help (yellowrexsi)
yeah thats at idle.. .. and it goes up to about 52 psi when i rev it ..
Old Apr 12, 2006 | 09:36 PM
ludesrv's Avatar
Your in limp mode...
I don't know if stock EF have it, but the car gets stuck at 3000-3500rpm. It won't go any further to preserve itself, but it will still get you home, like a true honda would.
Engine lights? ECU lights?
Old Apr 12, 2006 | 09:45 PM
only1gcue's Avatar
Default Re: (ludesrv)
how do i get it out of it ?? its b series in there .. it use to overheat .. if that helps .. i fixed that problem now this ..
Old Apr 12, 2006 | 10:19 PM
ALLMOTORCRX20's Avatar
Default Re: (only1gcue)
does your car have a check engine light??
if it does, what codes does it flash??
Old Apr 12, 2006 | 10:32 PM
only1gcue's Avatar
Default Re: (ALLMOTORCRX20)
the light has been on since the first time it was turned when we finished the swap.. but i ave no access to a scaner tonight.. i'll check it tomorrow..any idea what it might be ..
Old Apr 12, 2006 | 10:56 PM
gsxr1k05's Avatar
https://honda-tech.com/zerothread?id=468260
check this out.. for your ecu code reading pleasure
Old Apr 14, 2006 | 08:50 AM
ludesrv's Avatar
Ya man...your problem is limp mode. You probably have a shot sensor after your swap, it just gave out now and won't allow you to rev. Read your codes and then search for an answer.
duckiexd
Mar 25, 2010 07:07 AM
billabongkid13
Jan 25, 2008 05:18 AM
HT Chaplain
May 3, 2003 06:33 PM
hb_racer
23
Nov 23, 2001 09:44 AM
