LS/vtec ignition and cam timing
Old Apr 11, 2006 | 11:15 AM
Zatzy's Avatar
Default LS/vtec ignition and cam timing
I have a built up ls/vtec but with no timing cover and I was told that there is a mark on the face of the oil pump where i can set the ignition timing but i cant seem to find the one i was told about. does anyone have a pic of this mark?
On another note i have aem cams gears that at the moment are set to 0 and i was wondering how you set them on a DOHC engine. The head and block have been shaved although i cant remember the exact amount.
If anyone can give me a hand with these two issues that would be great...thanx in advance
Old Apr 11, 2006 | 09:39 PM
Zatzy's Avatar
Default Re: LS/vtec ignition and cam timing (Zatzy)
bump
Old Apr 12, 2006 | 11:12 AM
Zatzy's Avatar
ttt
Old Apr 12, 2006 | 09:41 PM
Zatzy's Avatar
another bump
Old Apr 13, 2006 | 04:55 PM
Zatzy's Avatar
come on people...i know someone has the answer lay that answer on me
Old Apr 13, 2006 | 05:18 PM
SIXTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zatzy &raquo;</TD></TR><TR><TD CLASS="quote">I have a built up ls/vtec but with no timing cover and I was told that there is a mark on the face of the oil pump where i can set the ignition timing but i cant seem to find the one i was told about. does anyone have a pic of this mark?
If anyone can give me a hand with these two issues that would be great...thanx in advance</TD></TR></TABLE>
I dont have a pic, but it is true, there is a very small mark on the oil pump itself that when lined up with the line on the crankshaft sprocket reresents tdc. Another way to do this, kind of ghetto is take out the #1 spark plug and stick a long screwdriver down there and rotate the crankshaft until it comes all the way up. your camgears should be lined up at this point. If there are upside down then you are 180 degrees off and rotate the crankshaft one more revolution. The screwdriver will go all the way down then all the way up again. When it reaches it's peak then your cam gears should be lined up and you are at TDC. Hope i explained this right, good luck
Old Apr 13, 2006 | 05:21 PM
Zatzy's Avatar
Default Re: LS/vtec ignition and cam timing (sixty-seven point six)
well how do i do time my ingition with a timing light with that mark? does it act like the mark that would be on the timing cover? if so i guess all i need is the pic of that mark cuase im not sure where it exactly is
Old Apr 15, 2006 | 04:38 PM
Zatzy's Avatar
anyone?
Old Apr 16, 2006 | 09:38 PM
Zatzy's Avatar
i really do need help on this...so please someone answer my questions
Old Apr 16, 2006 | 11:08 PM
brg2nr's Avatar
I can help ya with this one too.
mhewitt
Apr 24, 2012 06:32 PM
kazaa1872
Jan 26, 2009 11:38 AM
Zatzy
Jan 25, 2006 09:21 AM
ILLSIC
Oct 20, 2004 01:16 PM
Drkaccrd
Apr 11, 2003 03:12 PM
