code 8 top dead center problem
Old Apr 10, 2006 | 08:18 PM
omgwtfhaxnub's Avatar
Default code 8 top dead center problem
I got this code so i replaced the distributor and the the light went away. when i pluged the jumper the engine light flashes a code 8 again. What gives ? anyone have any insight on this, searched but didnt find anything.
Old Apr 11, 2006 | 06:50 AM
Default Re: code 8 top dead center problem (omgwtfhaxnub)
up we go
Old Apr 12, 2006 | 01:32 PM
anyone smart with hondas out there ?
Old Apr 12, 2006 | 01:46 PM
si90rex's Avatar
Default Re: (omgwtfhaxnub)
i need more info about the car make year anything and what are u trying to do
Old Apr 12, 2006 | 03:38 PM
Default Re: (si90rex)
its an obd1 d16z6 in a 93 cx. code 8 was on so we replaced the distributor and the light turned off. no engine light is on but when we plug in the jumper we get a code 8 still what gives ?
Old Apr 12, 2006 | 03:52 PM
rainforest's Avatar
disconnect the back up fuse for 3mins and then recheck. it is now a temporary dtc and wont throw the light till it has a problem 2 more times.
Old Apr 12, 2006 | 08:13 PM
Default Re: (rainforest)
where is the backup fuse ? the more detail the better
Old Apr 12, 2006 | 10:26 PM
PurEvl's Avatar
make sure all the pins etc in the plugs are pushed in all the way on the dizzy plug/harness and make sure all the pins on the ecu are all the way in.
leflore
Feb 27, 2015 10:10 AM
crxaddikt
10
Sep 13, 2014 11:47 AM
waynesumner
18
Jun 26, 2013 07:42 PM
hb_racer
May 29, 2002 07:28 PM
