theft recovery...no power options working now??
Old Apr 9, 2006 | 04:26 PM
peiku's Avatar
Default theft recovery...no power options working now??
i got my 95 honda civic ex coupe running after they stole it. once we got it started, we tried to get the driver side window to go up becus it was stuck half way open. we tried the switch and nothing worked. we also tried the passenger side and the same thing. we checked the fuses and they are all there and the right ones too. then we checked to see if the power door locks worked. nothing either. then we moved onto the sunroof and it didnt work either. it seems as tho all the power accesories didnt work. we took off the dash and checked to see if the thieves had cut any wires underneath and they were fine. i need to get this running asap, so any help would be greatly appreciated.
Old Apr 9, 2006 | 04:31 PM
donvito#1's Avatar
Default Re: theft recovery...no power options working now?? (peiku)
check the fuses under the dash and under the hood
Old Apr 9, 2006 | 06:10 PM
peiku's Avatar
Default Re: theft recovery...no power options working now?? (donvito#1)
checked those and they are all there and correct amps.
Old Apr 10, 2006 | 03:31 PM
peiku's Avatar
bump
Old Apr 10, 2006 | 03:33 PM
ccjustin's Avatar
did they hot-wire the car? ie cut the main acc wire in the ign harness(not that that would help start the car, but you never know) also check the bigger fuses under the hood
Old Apr 10, 2006 | 04:13 PM
. L 3 3 7 H X R's Avatar
they've cut your ESC main harness... =[ ur screwed
Old Apr 10, 2006 | 06:55 PM
peiku's Avatar
Default Re: (L337HXR..)
no they didnt hotwire the car. they just broke the steering lock and took that white plug thingy off to start the car.
where is the esc harness? the dash is off right now and there are no wires that were cut. there are also no left over plugs.
Old Apr 11, 2006 | 10:51 AM
peiku's Avatar
Default Re: (peiku)
bump
Civic_4life
Jan 2, 2012 04:34 PM
KRZRICAN
Dec 31, 2008 08:32 AM
spydertech02
Sep 12, 2005 09:19 AM
HKJ
Mar 18, 2003 06:26 PM
John
May 1, 2002 06:41 AM
