How do I wire up my harness?
Old Apr 9, 2006 | 01:53 PM
oneforce's Avatar
Default How do I wire up my harness?
I did a swap on my 96 civic ex coupe...I swaped in a us b16a2 and now im having an issue with my wiring.. can Anyone out there that has done this swap let me know how the wiring works?
Old Apr 9, 2006 | 01:56 PM
john666's Avatar
Default Re: How do I wire up my harness? (oneforce)
could you be a bit more clear whats the prob bob
Old Apr 9, 2006 | 02:01 PM
oneforce's Avatar
Default Re: How do I wire up my harness? (john666)
my stock ex harness has all the ecu plugs in the engine harness. the si harness i got has only two plugs to the ecu. Problem is i need to take out the remaining plug in the si to plug into my ecu, but that plug carries with it the dash harness? how do i get that plug out, or can i cut the si interior harness and just use the plug?
Old Apr 9, 2006 | 02:07 PM
professor poon's Avatar
is the motor from a 99 si or a 00 si? 99 is obd2a, 00 is obd2b. sounds like its a 00 and you need a wiring harness.
Old Apr 9, 2006 | 02:28 PM
TspEk9's Avatar
it'll be easier to use the 96-98 harness, and run a p30 ecu ( obd2 del sol ) or u can get a conversion harness to obd1 and run a chip p28
Old Apr 9, 2006 | 02:29 PM
oneforce's Avatar
which wiring harness?
can i use my ex one?
Old Apr 9, 2006 | 02:47 PM
oneforce's Avatar
Default Re: (oneforce)
one of the in dash harness plugs into the ecu. that's the one im missing, on the other hand my y8 harness has all the plugs on the engine harness, can i cut the si interior harmess and splice it into my existing in dash harness?
Old Apr 9, 2006 | 03:57 PM
oneforce's Avatar
I FOUND OUT, I NEED TO BUY THE DAMN JUMPER HARNESS
Old Apr 11, 2006 | 02:46 AM
TspEk9's Avatar
bingo
da59block
14
Nov 11, 2011 12:33 PM
clark81
Sep 5, 2010 11:52 AM
nello a.
Dec 24, 2008 12:20 AM
mrjenkins
Jul 4, 2008 01:03 PM
june
Nov 30, 2001 06:49 PM
