anybody running an LS turbo? if so, what all do you have done?
Old Apr 5, 2002 | 11:32 AM
Jonathan_ED3's Avatar
Default anybody running an LS turbo? if so, what all do you have done?
i have an LS in my 92 civic HB w/ 60K on the motor. i want to get the car into the low 13's on street tires. will i be able to do this as a daily driver and not have to build the motor any? i don't want to be pushing it at all, as this is my only car. what would you guys recommend? FMAX has a kit designed for a 5g civic hatch w/b18b1 what do you guys think?
Old Apr 5, 2002 | 11:59 AM
BlowOff's Avatar
New User
Default Re: anybody running an LS turbo? if so, what all do you have done? (hot_EF)
Daily driven and 13 sec? Hmmmmm? I guess you could but you would have to dyno the hell out of it and make sure it is tuned perfectly. How many lbs will you be running?
Old Apr 5, 2002 | 01:45 PM
Default Re: anybody running an LS turbo? if so, what all do you have done? (BlowOff)
well....that's what i'm asking. i don't know how much boost to run!!!!??? that's what i'm trying to find out. what's a safe level on stock internals? i heard 7 is the max. how much are you running, and what kit are you using?
Old Apr 5, 2002 | 05:17 PM
SIK IN DA HED's Avatar
New User
id stick to a drag3 or revhard kit.
fmax
a LS motor can handle 9lbs safely... but id boost no more than 7lbs. you can easily hit 13s with 7lbs. just get everything installed right... have a good free flowing exhaust... and some tuning... youll be good to go. you wouldnt even have to build your motor. thats for later on when you turn into a boost junkie.
Old Apr 5, 2002 | 06:02 PM
BlowOff's Avatar
New User
I have a completely built motor. Bored, sleved, rods, pistons, blah....I am only running 7 lbs right now but will bump it up to 12 when I get to the damn dyno! Oh, and I'm running a custom turbo system with a T3/T4 turbo.
On a hatch, you will be fast with 7 lbs. Just remember to give it enough fuel (injectors, FMU, fuel pump, SAFC or Hondata).
Old Apr 5, 2002 | 11:03 PM
New User
[QUOTE]I have a completely built motor. Bored, sleved, rods, pistons, blah....I am only running 7 lbs right now but will bump it up to 12 when I get to the damn dyno! Oh, and I'm running a custom turbo system with a T3/T4 turbo.
QUOTE]
eg6turbo143
11
Dec 7, 2006 09:22 AM
hinds90
Apr 21, 2005 04:18 PM
hypnothaiz
Jun 21, 2004 06:51 PM
ilovemixedrice
Apr 17, 2004 06:18 AM
Rasta
Oct 12, 2003 10:04 PM
