Another Turbo Ls
Old Apr 18, 2005 | 01:12 PM
hinds90's Avatar
Default Another Turbo Ls
I have a 91 civic hatch with a Ls and I am planning on getting a full greddy kit. I want a car that is very reliable ( motor is stock) so what boost should I run 6psi or 8.
Old Apr 18, 2005 | 01:14 PM
drift2004's Avatar
Default Re: Another Turbo Ls (hinds90)
1OPSI
Old Apr 18, 2005 | 01:18 PM
hinds90's Avatar
Default Re: Another Turbo Ls (drift2004)
Is 10psi reliable for a race. I paln on running 2psi for daily driving.
Old Apr 18, 2005 | 01:28 PM
1RMDave's Avatar
if you only want 2 psi daily then save some time/effort and just use nitrous when you race instead of turbo
Old Apr 18, 2005 | 01:29 PM
Nytmair's Avatar
if i had an LS turbo (which i plan on in the future...) i would hate only have 2psi, but tha'ts just me ... but yeah i am thinking of running 10psi just to be safe, AFAIK around 14 is the limit on stock internals.
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote"> I paln on running 2psi for daily driving.</TD></TR></TABLE>
haha, what?!
Old Apr 18, 2005 | 01:30 PM
dustin's Avatar
10psi is fine.
Old Apr 18, 2005 | 01:37 PM
hinds90's Avatar
Default Re: Another Turbo Ls (1RMDave)
I mean I plan on running 2psi when I am not racing or showing off. The question was what psi should I run when I am racing.
Old Apr 18, 2005 | 01:46 PM
nota-ex's Avatar
I've heard that 8psi is good for daily driving. I have no idea how much boost the stock b18 internals can hold, mabe 10/12 psi.
Old Apr 18, 2005 | 01:47 PM
dustin's Avatar
10psi on the greddy kit should be fine.
Old Apr 18, 2005 | 03:06 PM
ProjectDarkBlack's Avatar
Default Re: Another Turbo Ls (dustin)
greddy = 8psi/////// 10psi
2 psi is just whack
Old Apr 18, 2005 | 03:09 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Another Turbo Ls (ProjectDarkBlack)
the spring in the greddy wg is like 5psi.... so how do you plan on running 2psi... which is the dumbest thing EVAR!!!!!!!!!
dustin's Avatar
Default Re: Another Turbo Ls (wantboost)
just drill a 3/4" hole in the charge piping somewhere
Old Apr 18, 2005 | 03:31 PM
Si Shane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">just drill a 3/4" hole in the charge piping somewhere</TD></TR></TABLE>
lol!!!!!!! If you want to run NO boost!!!
For 2 psi with a greddy kit on an LS motor you drill a 1/16" hole 5.5" from the Throttle body.
Old Apr 18, 2005 | 04:21 PM
adseguy's Avatar
Default Re: Another Turbo Ls (Si Shane)
HAHAHA...i love it, but i don't think this guy is goin to get all the sarcasm.
You obviously need to take the wastegate vaccum nipple off so it can bleed off to the atmosphere and you'll only boost like 2.4 PSI
Old Apr 18, 2005 | 05:55 PM
batboyvaj's Avatar
Default Re: Another Turbo Ls (adseguy)
2psi???? hahahaha might as well just run a intake
Old Apr 18, 2005 | 06:20 PM
DurboDug93's Avatar
I running mine on 10psi. Bone stock B18A, 102,000mi
Old Apr 18, 2005 | 06:49 PM
nota-ex's Avatar
Default Re: (DurboDug93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DurboDug93 &raquo;</TD></TR><TR><TD CLASS="quote">I running mine on 10psi. Bone stock B18A, 102,000mi </TD></TR></TABLE>
You hit full boost around 4500?
Old Apr 18, 2005 | 07:13 PM
DurboDug93's Avatar
somewhere around there. I can thank the .63ar for that
Old Apr 18, 2005 | 07:42 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">Is 10psi reliable for a race. I paln on running 2psi for daily driving.</TD></TR></TABLE>
Dude 2psi daily driven is honestly useless. 6-8psi daily driven is 100% fine for a stock motor. 10psi would be the limit I would take it even on a race day. (just my opinion because I like reliability more than a big whp number). But with tuning things are good to go. 2psi=not useful. Just tune it to like 8psi daily and 10 on race days and you will be fine.
Old Apr 18, 2005 | 07:52 PM
blackeg's Avatar
Default Re: Another Turbo Ls (nota-ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-ex &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that 8psi is good for daily driving.</TD></TR></TABLE>
im on 7.25psi right now and for daily its more than fine imo.
You hit full boost around 4500?</TD></TR></TABLE>
im hitting 7psi with a 57trim .63 turbine at about 4700ish. are you running a boost controller to help with the spool time?
Old Apr 18, 2005 | 07:57 PM
SOHC_MShue's Avatar
2psi? Bwahahahahaha!
Old Apr 18, 2005 | 08:12 PM
AspectIndustries's Avatar
Default Re: Another Turbo Ls (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
im hitting 7psi with a 57trim .63 turbine at about 4700ish. are you running a boost controller to help with the spool time?</TD></TR></TABLE>
I hit 7psi around 3,500rpm.. o_O Same size Turbo... Manual Boost controller here..It helps spool times a bit..
Old Apr 18, 2005 | 08:14 PM
DurboDug93's Avatar
Greddy Profec B spec II
Old Apr 18, 2005 | 08:32 PM
5litereater's Avatar
Default Re: (Nytmair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nytmair &raquo;</TD></TR><TR><TD CLASS="quote">if i had an LS turbo (which i plan on in the future...) i would hate only have 2psi, but tha'ts just me ... but yeah i am thinking of running 10psi just to be safe, AFAIK around 14 is the limit on stock internals.</TD></TR></TABLE>
ive seen 17 psi with a good tune. but thats REALLY pushing it.
correct me if im wrong, but i dont think anyone makes a 2psi spring stock? most are set at 4 psi stock. that would mean DOWNGRADING just to run less boost. its your kti so i can tell you what to do, but if i were you id spend the money on making the car go faster, no slower...
good luck either way.
boost
