What ?'s to ask when Buying a used motor?
Old Apr 7, 2006 | 09:14 PM
atmosphere's Avatar
Default What ?'s to ask when Buying a used motor?
i might be coming up on a used jdm gsr motor for a really good price, almost too good to be true. What should i look for when inspecting the motor? questions to be asked? i just dont want to get jipped here so all comments are appreciated. Thanks.
Old Apr 7, 2006 | 09:18 PM
1995Ex_Sedan's Avatar
Nevermind.
Modified by 1995Ex_Sedan at 11:35 PM 4/7/2006
Old Apr 7, 2006 | 09:57 PM
Syndacate's Avatar
nvm...
Old Apr 7, 2006 | 09:58 PM
SiYouLater's Avatar
Default Re: (Syndacate)
I don't know what you can ask. Buying motors are basically a visual thing to inspect.
Old Apr 7, 2006 | 10:02 PM
professor poon's Avatar
Default Re: (99FBPSi)
compression/leakdown results are pretty much the only non-visual facts you need. Also mileage, how many owners, etc... What is the price btw?
Old Apr 7, 2006 | 10:46 PM
ZipTieGUy's Avatar
ask them where the hell the motor came from and for a copy of the title of the car it was in, could be stolen for all your know
Old Apr 8, 2006 | 04:17 AM
fmrprojects's Avatar
Default Re: (ZipTieGuy)
ask what was leak down, compression #s when motor was running. how many miles on it. and check the plugs see what they look like, does the motor leak, use a ratchet to turn the crank see if the motor still turns
Old Apr 8, 2006 | 05:07 AM
92civichatch1's Avatar
Default Re: (fmrprojects)
as far as the leakdown results they may have for u. A motor shouldnt leak more than 10-15%. The compression test im not exactly sure what a gsr should get but most hondas are 160. Def. pull all spark plugs out. thats all u can really do besides a thorough visual inspection too
Old Apr 8, 2006 | 08:06 AM
GSR compression test should be 190-220 range. mine was 200-200-195-195
Old Apr 8, 2006 | 08:11 AM
CALIdelsolSIR's Avatar
Default Re: (professor poon)
pray the motor is still in the car and you can start it up before buying
other then that, compression/leakdown --> look for oil coming out of strange places -- check many of the gaskets -- really, like stated above, it is pretty visual
EDIT: Definately take a ratchet to the crank and see if it cranks. If the block doesn't crank, the engine is most likely seized and all melted together inside. When that happens, the block is as good as dead
Old Apr 8, 2006 | 11:34 AM
delsolmidget's Avatar
Default Re: What ?'s to ask when Buying a used motor? (atmosphere)
if you are still wonderig about this you might want to ask the seller to give you the results of compression tests, and cylinder leakage test. the results of these test will give you an idea of how well maintained the engine is. especially ask how many miles are on the engine but those tests will tell you the most about the state of the cylinders.
Old Apr 8, 2006 | 01:23 PM
EM199dcs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere &raquo;</TD></TR><TR><TD CLASS="quote">i might be coming up on a used jdm gsr motor for a really good price, almost too good to be true. What should i look for when inspecting the motor? questions to be asked? i just dont want to get jipped here so all comments are appreciated. Thanks. </TD></TR></TABLE>
Ask them miles on the motor. Why the motor was pulled out of the car..wrecked,totalled. ask is it legit does it have papers. if the engine starts. if there is anything blown on the engine. and make sure you look at it and make a little inspection make sure everything looks right.
Old Apr 8, 2006 | 02:02 PM
SiYouLater's Avatar
Default Re: What ?'s to ask when Buying a used motor? (EM199dcs)
The compression results and leakdown results can be bullshitted. Make sure the motor is in a car and able to run so you can run those tests on it.
Randysi
11
Jun 27, 2011 06:12 AM
DpQInteg
May 2, 2006 01:28 PM
prelude1897
Apr 26, 2006 11:46 PM
IgniteTeg
Oct 30, 2002 12:34 PM
S13 slide
Feb 6, 2002 05:50 PM
