92 civic hatch BRAKE BOOSTER NEED HELP!!!!!!!!!!!!
is there any correct way of replacing a brake booster on a 92 civic or is it just taking out the bolts inside the car and bolting up the new 1???
does it need any adjusting or anything like that need info on this thanks for the help in advanced
you can pull it out w/o removiing the master, but it's kinda a pain. Just do it write,a nd rebleed the brakes, and remove the master too. The must be a reason why the booster went bad. Must be a master leak, into the booster, or are you just upgrading?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gdm92hatch »</TD></TR><TR><TD CLASS="quote">up top so theres nothing 2 adjust or nothing just plug n play lol</TD></TR></TABLE>
Yes, it's truly plug and play. Make sure you get the cotter pin back in the rod that connects the rear of the BB to the brake pedal or you might find yourself without brakes at a rather inoportune time.
qpzm12
Oct 7, 2010 08:24 PM
4DALOOKS92
Feb 14, 2009 08:14 AM
