Milled head
Old Apr 5, 2002 | 05:08 AM
tecnic1's Avatar
Default Milled head
How far do I have to mill my head to hit 11.6-8-1 and would I have clearance issues with Toda Bs and a 2 layer headgasket? Would it be worth my money to get it ported and polished while it's at the machine shop?...I'm really not sure I want to do this, but I could theoretically be done with my engine and not screwing around for another few months trying to get compression after I install the Bs...thanks
[Modified by tecnic1, 2:17 PM 4/5/2002]
Old Apr 5, 2002 | 05:20 AM
Mike K's Avatar
Default Re: Milled head (tecnic1)
By the time you raise your stock compression MORE than a point(11.8:1), you'll be at the quench pads. LOL.
I wouldn't feel safe running CTR cams with that kind of clearance.
Don't mill more than 15 or so.
Old Apr 5, 2002 | 05:21 AM
Lip's Avatar
Lip
Default Re: Milled head (Mike K)
nah. you can mill like the thickness of a pj sandwich and really get some compression
Old Apr 5, 2002 | 05:22 AM
Mike K's Avatar
Default Re: Milled head (Lip)
lol. most i have done is 40 thou on a stock GSR motor w/ ITR cams.
awesome comparison. lol.
Old Apr 5, 2002 | 05:26 AM
tecnic1's Avatar
Is that a PJ sandwich on sandwich slice bread or regular sliced bread cause there has to be at least 20 thou or so difference.....LOL. So 15 and the 2 layer would get me 11.8 about?...will that make me happy? Will I get that "mid range power" I would trade my first born for?
[Modified by tecnic1, 9:30 AM 4/5/2002]
Old Apr 5, 2002 | 05:48 AM
Lip's Avatar
Lip
no. the proper pistons will make you want to trade your first born
Old Apr 5, 2002 | 05:53 AM
tecnic1's Avatar
With proper pistons and proper install i won't be able to afford my first born. I would love to get them, but it's not going to happen any time soon.
Old Apr 5, 2002 | 06:22 AM
smerk's Avatar
New User
Try using the calculator on: http://www.c-speedracing.com/howto/c.../compcalc.html
select the 2 layer gasket and then subtract how many thousandths of an inch you want to mill and modify the thickness number accordingly. You may end up with a negative number on the thickness but I think that still works.
While we're on the subject, anyone know how to calculate how much to advance the cam gears to compensate for x amount milled?
Old Apr 5, 2002 | 06:48 AM
tecnic1's Avatar
Default Re: Milled head (smerk)
That's depressing....milling 20 thou with the 2 layer only got me 11.4:1....
Old Apr 5, 2002 | 07:36 AM
t's Avatar
t
If your going to mill the head, Why use a 2-piece gasket?
Mill 30thouandths off and use a 3-layer gasket. and you will get your approx. compression ratio.
Old Apr 5, 2002 | 07:45 AM
tecnic1's Avatar
Default Re: Milled head (t)
I already own the two layer, and I can always replace the head gasket, but once I mill the head, it's milled.
all-mtr-teg
15
Nov 30, 2006 08:43 PM
Ti3d in
Jul 11, 2004 02:45 PM
iblewmyrmotor
Apr 14, 2003 07:48 AM
SIReg9
Jan 18, 2003 11:49 AM
Mr. Softee
Aug 21, 2001 12:55 PM
