13:1 compression. What do i need to tune?
After i blew up my B16, I ended up with a GSR shortblock, and just came across a GSR head, Turnes out the head was milled. So the CTR pistons i got will bring it up to about 13:1 after its all said and done.
Might be stupid of me to build this...cus in the long run i want to build it for turbo, and i have a year without my licence.
Does it seem streetable with 13.1? What will i need to tune it?
PS: head is for sale $250 if intrested
I would ditch that head and find a new one... Get some high lift long duration cams with a lot of overlap to bleed off some compression... 13.0:1 is cool but your head has to be milled quite a bit to achive that compression with only CTR slugs... Hook up a Hondata S200 system and you'll be set... Good Luck
sgT what do you figure the compression ratio of a stock B18C1 with CTR slugs in it at say 0.25mm overbore?? I'm just curious... What increase are are you getting from just milling the head 0.010"... Latez
I'm sorry but why would you ever consider building this when you know you want to go turbo??
Can't you just wait it out, do it right, and boost it?
Why bother building N/A?
