Honda S2000 Honda S2000
poss bad ring??
Old Apr 7, 2006 | 07:13 AM
GDM Ap1's Avatar
Default poss bad ring??
Ok So i have my head off my car . for the past few weeks ive been hitting my bare engine with wd40 to keep it lubed and no corosion. Today I notice that 3 of the cylinders have wd left in them but the first cylinder was bare no fluid on top of the piston. Im thinkin maybe the rings are shot or maybe the wd is just to thin? inputs please... or could it be that due to the motor not running the rings arent expanding?
Car has 44k on it never boosted before
Old Apr 7, 2006 | 09:26 AM
b18c195's Avatar
do a compression test it should show up!!!
Old Apr 7, 2006 | 09:34 AM
GDM Ap1's Avatar
Default Re: (b18c195)
No head on the car
Old Apr 8, 2006 | 08:58 AM
evil vapor's Avatar
Default Re: poss bad ring?? (GDM Ap1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GDM Ap1 &raquo;</TD></TR><TR><TD CLASS="quote">Ok So i have my head off my car . for the past few weeks ive been hitting my bare engine with wd40 to keep it lubed and no corosion. Today I notice that 3 of the cylinders have wd left in them but the first cylinder was bare no fluid on top of the piston. Im thinkin maybe the rings are shot or maybe the wd is just to thin? inputs please... or could it be that due to the motor not running the rings arent expanding?
Car has 44k on it never boosted before</TD></TR></TABLE>
Don't worry. WD is pretty light and usually dries up. It's probably a fluke that one cylinder dries up. I wouldn't spray it down each time with WD since you have your head off. Use synthetic engine oil, it'll coat the cylinder walls better and do it only once. Keep the block covered to prevent dust and other stuff from getting in there. Change your oil before you start it up once the engine is back together. It doesn't hurt to crank the engine over a few times to get oil pumping before you fire it up.
Old Apr 10, 2006 | 06:58 AM
GDM Ap1's Avatar
Default Re: poss bad ring?? (vapor)
Just got into work this morn and oil level in my piston is where it was before the weekend so im happy thanx vapor
Old Apr 10, 2006 | 07:23 AM
pushinlsteg's Avatar
yeah all you should need is a thin coat of motor oil to keep things good, at least everything is built up of some form of aluminum and wont rust.
Old Apr 10, 2006 | 11:07 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GDM Ap1 &raquo;</TD></TR><TR><TD CLASS="quote">Just got into work this morn and oil level in my piston is where it was before the weekend so im happy thanx vapor</TD></TR></TABLE> It's always best to be on the side of caution and concern.
hondachris1994
11
Mar 2, 2008 03:23 PM
bOOsT-FeIn
Oct 17, 2006 06:53 PM
4gencivicef9
Jun 27, 2006 05:51 PM
dc-lefty
Mar 2, 2004 11:14 AM
DAinfamousR
May 9, 2003 11:35 PM
