fixing a 95 ex crash
Old Apr 6, 2006 | 05:16 PM
doggworld1233's Avatar
Default fixing a 95 ex crash
ok so i had a crash in my ex today and took off the bumper that was cracked. oppon removal there was a Black metal( bumper mounts to it in a way by lights) bar about the size of a 2 x 4 bent so i pulled it out with a rope but i was wondering if i could remove this and get a new one? also how do i take it out? i found 4 bolts but can take them out beacuse 2 are in a odd angle.
justin
Old Apr 7, 2006 | 08:20 AM
Default Re: fixing a 95 ex crash (doggworld1233)
bump
Old Apr 9, 2006 | 10:36 AM
bump come on HT
Old Apr 9, 2006 | 10:59 AM
Default Re: (doggworld1233)
Old Apr 9, 2006 | 11:11 AM
wheelmanbg's Avatar
are you talking about the actual bumper?
I've never taken one off but I'm sure you can take it off and replace it with a new one
Is it making your bumper sit bad or what?
Old Apr 9, 2006 | 11:12 AM
Default Re: fixing a 95 ex crash (wheelmanbg)
i am talking about the black metel thing with a dent in it. it looks like a 2 x 4.
Old Apr 9, 2006 | 11:16 AM
Soccerking3000's Avatar
eh just remove it there are 4 bolts holding it on...
Old Apr 9, 2006 | 11:59 AM
93gsrcoupe's Avatar
Default Re: fixing a 95 ex crash (Soccerking3000)
The part you're refering to is what we call a re-bar. Just remove the four bolts(you may need air) and it'll drop right off.
Old Apr 9, 2006 | 02:56 PM
isumase's Avatar
Default Re: fixing a 95 ex crash (93gsrcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">i am talking about the black metel thing with a dent in it. it looks like a 2 x 4. </TD></TR></TABLE>
that would be your actual bumper, the plastic "bumper" is just the bumper cover as that adds no protection
as to your question, id pull it off and just replace it from a junkyard.
Old Apr 9, 2006 | 03:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">The part you're refering to is what we call a re-bar. Just remove the four bolts(you may need air) and it'll drop right off.</TD></TR></TABLE>
no its the bumper, the plastic/urethane most people call the bumper is actually called the bumper cover.
Old Apr 9, 2006 | 03:25 PM
john666's Avatar
just make sure to get a oem honda one.. the after marks onces are a bit cheap lol
Old Apr 9, 2006 | 04:47 PM
ok so i have a prob i can only get 2 bolts off the other two are behind a plate that is all fucked up on both sides. any ideas how to get it off? also the bumper cover is cracked can i fix it ?? and what is the price for a new oem one(from honda)
Old Apr 9, 2006 | 04:49 PM
there shouldnt be anything covering them, therewould have been 2 plastic pieces (one on each side) covering one of the holes but those just pull out...
Old Apr 9, 2006 | 04:52 PM
93gsrcoupe's Avatar
Look guys, I work at a body shop, the metal black bar is the bumper reinforcement bar (re-bar), the plastic piece is the bumper cover, and theres also usually an abosorber thats styrofoam(between the cover and the re-bar).
Old Apr 9, 2006 | 04:58 PM
it doesnt matter if you work at a bodyshop, its the bumper cover or bumper face, and the beam underneath is the actual bumper/bumper beam
http://www.hondaautomotivepart...UMPER
by what your saying there are things that surround a non-existant piece on the front of the car...
Old Apr 9, 2006 | 05:12 PM
i would like some one to get back on topic. and help me out
Old Apr 9, 2006 | 06:51 PM
john666's Avatar
cut a hole or bend the metal so u can get to the screws and remove it.
heres a better pic of what your talking about. on this site its called front reinforcement.
Old Apr 9, 2006 | 07:27 PM
93gsrcoupe's Avatar
Default Re: (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">cut a hole or bend the metal so u can get to the screws and remove it.
heres a better pic of what your talking about. on this site its called front reinforcement.</TD></TR></TABLE>
Thanks john666
Old Apr 10, 2006 | 07:16 AM
ok now my question is when i go to the junk yard will i have to cut the thing to get it out or will it unbolt?
Old Apr 10, 2006 | 08:18 AM
suspendedHatch's Avatar
Damn homie, try reading people's replies. It's BOLT on.
You don't need one. The purpose of that bar is to minimize $$$ damage on low speed collisions, typically driver's errors when parking.
Old Apr 10, 2006 | 09:08 AM
doublejz's Avatar
Default Re: (suspendedHatch)
ummm they are kinda important. They also connect at the ends of the wanna be frame. the rad support helps some but this also strengthens the front end of the frame.
Old Apr 10, 2006 | 02:13 PM
93gsrcoupe's Avatar
Default Re: (doublejz)
Dude, you def should have the re-bar on there (kind of a safety issue) and it protects your radiator as well. Like doublejz said, the only thing behind it is the rad support, and its in your best interest to not damage that (costs more to repair).
EJ8VTEC
Oct 1, 2005 08:11 PM
bobby_booshay
May 26, 2004 11:55 PM
rwallyr
May 7, 2004 09:29 AM
2ksilverex
10
Apr 27, 2004 06:19 PM
DJ Rub-ISH
Oct 20, 2003 11:43 PM
