need help identifing this ecu and possible chip
this came out of a friends car, that he had bought used. hes doing a swap and when you took the ecu out to replace it he found this. no label on the ecu and when i opened it up it looks like its been chipped but im not sure. also i have no idea what chip it is....wanna get some answers for him ...... anyone know?
you said it came out of your freinds car, what car is it? And a chipped ECU means that it's been modified with a performance chip. and im afraid SST doesn't do performance. There is a sticker on the outside on the opposite side of the ecu plug in (the big one) the sticker usually has a barcode and somewhere you will see P29 or something like that. is your sticker missing? if it is, it's also printed on the green silocone in white print. should have a P and 2 numbers
i know that....if it were that simple id know what this is.....thats why im asking this to the people who chip ecus and who could recognize them......the stickers are not on the ecu
Well think about it.
What kind of car did it come out of?
What kind of engine is in the car??
Is it OBD 2 or has it been converted to OBD 1?
There has to be a thread on here somewhere saying what ecu goes with what engine...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 »</TD></TR><TR><TD CLASS="quote">Well think about it.
There has to be a thread on here somewhere saying what ecu goes with what engine... </TD></TR></TABLE>
thats not helpful at all...i know it should be a virgin p28....question is does it look like a virgin p28? i dont know about the atanomy of it....someone told me its chipped, since im not sure im trying to verify that
just buy a chip that u like for ur motor, dohc or sohc, and pop it in and ur good to go
the ecu looks like its a converted ecu, like it was made into a p28 vtec
SST is the brand of the chip not the program
all u need to go is get a new chip, put it in, simply pull put the old, push in the new, and u know what your running and the spec's
how easy is that
how easy is that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">just buy a chip that u like for ur motor, dohc or sohc, and pop it in and ur good to go
how easy is that</TD></TR></TABLE>
thank you sir
thank you sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Indeed, it's chipped, only way to know what's on it is to send it to someone to read it, just get a new chip. SST chips are nice, flash reburnable and can hold two programs.</TD></TR></TABLE>
how would you switch between the 2 programs if it were so equiped....btw ill just pull the chip and get a new one but i was wondering none the less
alfaaay
Apr 7, 2004 12:20 AM
