LS BORED TO 2.0L.
Old Apr 5, 2006 | 04:53 PM
SILENTJ95835's Avatar
Default LS BORED TO 2.0L.
I currently have a LS motor that needs a rebuild in a EJ coupe. Been wanting boost(turbo) after having my SC b16 hatch i had to sell. One of my good buddies who helps/does alot of my work suggested to bore the LS to 84mm standard rebuild and just throw a Greddy Turbo kit with 6-8 lbs. (he knows his ****) Stock LS bottom end with bore/hone 84mm, rebuilt lower blah blah. The pistons are stock LS rods but with new B20z pistons. The head will be ported with the valve job from comptech. New ARP rod bolts.
Sounds like a good plan? Right??? Now that you have the gist of the story.......
1Has ne 1 done this type of rebuild??
2Are the cyclinder walls stable for boost with out sleeving? Planning to run 6lbs daily and 8 for racing.
3How much boost have you run on this set up before KAaaaboom???
4How reliable is the setup compared to a stock b20 turbo setup????
Old Apr 5, 2006 | 06:44 PM
Default Re: LS BORED TO 2.0L. (SILENTJ95670)
HMMMMM????
Old Apr 5, 2006 | 06:47 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SILENTJ95670 &raquo;</TD></TR><TR><TD CLASS="quote">3How much boost have you run on this set up before KAaaaboom???</TD></TR></TABLE>
23psi on a T60.
crxsteve
Nov 13, 2007 04:36 PM
fabe85
Apr 25, 2007 09:51 PM
SILENTJ95835
Apr 12, 2006 03:38 PM
del_orson
Jun 7, 2005 07:13 PM
p1ccoloz
May 1, 2003 02:09 PM
