B20 VTEC 94 Hatch
Old Apr 5, 2006 | 01:26 PM
HondaHead211's Avatar
Default B20 VTEC EK hatch
im lookin to put a hybrid b20 vtec in an ek hatch. i was just looking for some suggestions to make the process easy. the motor will be turboed with the full race kit. the b20 block im getting will most likely be a dart b20 block and i was debating on what head to go with. most likely a b16 or b18 head. my questions arent really mechanical they're more electrical. here is what i plan to do.
1. dart b20
2. b16 or b18 head
3. either jdm or usdm itr tranny
4. hasport motor mounts
5. hasport stage 2 axels
my questions are as follows
1. will the hasport mounting kit be complete or will i need t-brackets/tranny mounts etc
2. what ecu should i find to use...since i am going turbo i will be going with a hondata s200 which ecu will make my life easiest
3. what wiring harness do i need?
those are all the things that come to mind right now....if i left any unforseen problems out please enlighten me. you input is really appreciated.
Modified by HondaHead211 at 6:13 PM 4/5/2006
Old Apr 5, 2006 | 01:31 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: B20 VTEC 94 Hatch (HondaHead211)
for hasport mounts.. they should be comeplete.. just give them a call and find out..
any vtec ecu will work since it's gonna be altered by hondata s200.. like p28 which is obd1, gsr or b16 ecu will work to0..
i suggest going obd1 wireharness and stuff since your car is already obd1
my .02
Old Apr 5, 2006 | 03:10 PM
i thought ek hatches were obd2?....correct me if im wrong
Old Apr 5, 2006 | 04:54 PM
Chris Benoit's Avatar
I think everyone is confused because the title of your post says 94 civic, which is EG, but in the post you say EK.
Old Apr 5, 2006 | 07:44 PM
i meant ek i typed the wrong thing and then tried to edit it but it doesnt change the title
EK HATCH NOT EG
Old Apr 19, 2006 | 06:58 PM
Default Re: (HondaHead211)
oh well in that case get a obd2 b16 SI ecu. that works and plug s200 up to itt
sick90hatch
18
Nov 18, 2008 01:19 PM
immrtaltchnq
Oct 21, 2008 07:46 AM
Ole' B18
Dec 27, 2007 04:56 AM
crx91spoon
Dec 11, 2005 03:08 PM
EKmonsta
Dec 16, 2004 09:55 AM
