Forged pistons - stock rods?
Old Apr 5, 2006 | 11:17 AM
MoonScryer's Avatar
Default Forged pistons - stock rods?
I'm currently rebuilding a b18a for boost, and I am on a budget. I have a set of SRP pistons I would like to use vs. using the stock ones. Problem I ran into is I either buy OEM Honda parts and use stock shotpeened rods (do I need to shot peen them??) or I buy aftermarket parts (bearings etc) and get forged rods.
I will be running 8-10psi, no more.
Thanks
Old Apr 5, 2006 | 11:27 AM
skratchnsnift's Avatar
you can use stock rods/pistons for the psi you'll be running.
Old Apr 5, 2006 | 11:31 AM
mike1114's Avatar
Default Re: (skratchnsnift)
I was in the same situation as you once.....
I know its tough, but save up and get the rods too! yes you can use stock rods and forged pistons for the power levels your running but you will eventually want to turn up the boost. If you do this now, you save yourself a complete rebuild later just cause you need to put rods in. This is what I had to do.
Rods can be found for less than $300 dollars. Patience is a virtue.
Old Apr 5, 2006 | 01:02 PM
ProjectDarkBlack's Avatar
Default Re: (mike1114)
you can lie to yourself all you want, but eventually, you will want more boost
Old Apr 5, 2006 | 01:39 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: (ProjectDarkBlack)
check the forced induction sponsor classifieds, they have a lot of great deals for piston/rod combos.
eagle rods for the performance and price
Old Apr 5, 2006 | 03:27 PM
MoonScryer's Avatar
Yeah, I was thinking the same thing. This is my first engine build, got a excellent mechanic helping - advice only, I insist on doing it myself - but didn't want to cut corners, honestly. Heh, yeah I'll probably want more later on, so forged rods it is. I can wait a month more; I've waited three years already.
Thanks.
GEN2 LS
Sep 11, 2012 09:06 PM
sasinorm01
Oct 4, 2007 11:54 AM
StylishDOHC
Mar 23, 2006 09:42 AM
blocburner1
Feb 3, 2006 04:17 PM
B18B1DOHC
Sep 23, 2003 11:09 AM
