password jdm intake on a '00 civic ex?
Old Apr 5, 2006 | 09:57 AM
hkt03's Avatar
Default password jdm intake on a '00 civic ex?
i've searched and really cant find much..
i finally got the password:jdm cf intake, and i've been searching since i bought it but havent found much info on it.
there is one tube going into the stock intake from the valve cover, there is the sensor plugged into the stock intake, and there is another metal tube (that later goes into a tube) that plugs into the stock intake.
the password intake only has a hole for the sensor and the vc tube. i dont want to drill another hole, so how do i go about being able to plug in that last metal tube?
i'm going to assume that i'll most likely have to buy some sort of y-connector to plug in that metal tube with the vc tube.
i was going to replace the metal tube with a rubber one and run it to the intake and then place a breather filter on the vc but i've read around a bit and that doesnt sound like too good of an idea..
intakes going on a stock ' 00 d16y8.. any help would be appreciated
Old Apr 5, 2006 | 10:36 AM
BJOnewiper's Avatar
I run mine right to the valve cover breather. King Motorsports just worked over my car, and they had no porblems with that.
Old Apr 5, 2006 | 11:51 AM
hkt03's Avatar
Default Re: (notoriousEJ8)
sent you a PM..
anyone else?
Old Apr 6, 2006 | 11:25 AM
hkt03's Avatar
Default Re: (hkt03)
bump.. anyone else?
Old Apr 6, 2006 | 02:08 PM
dwnthehatch's Avatar
Default Re: password jdm intake on a '00 civic ex? (hkt03)
Mine had two holes in it. One for the crankcase breather hose and one for the IAT . Did you order the 92-95 intake by mistake?
Old Apr 6, 2006 | 07:23 PM
hkt03's Avatar
Default Re: password jdm intake on a '00 civic ex? (dwnthehatch)
to my understanding.. the password jdm comes w/ two holes.
the 96-98 sohc ex stock intake has two holes, but the 99-00 ex stock intake has three.
Old Apr 12, 2006 | 07:35 PM
00CivicGirl's Avatar
mine came with 2 holes. both of which were plugged obvisously..i swapped out my sensor off my old intake and put it on the new one..the tube i ran from the intake to the breather on the motor
i have had no problems. no cel and it sounds nice
i can try to get some pics tomorrow if you need them
Old Apr 13, 2006 | 04:54 AM
hkt03's Avatar
Default Re: password jdm intake on a '00 civic ex? (00CivicGirl)
i've had mine it on for a few days now, but runnin' it using a breather filter while i figure out some way to use a y-connector to run both hoses into the intake.
but if you can, a pic or two would be great, thanks.
Mr. H_Twizzle
Apr 16, 2012 01:52 PM
illios
Oct 9, 2007 02:05 PM
coolpix99
Nov 5, 2005 10:37 PM
darkknightwong
Mar 16, 2002 04:31 AM
Minorgliche
Aug 26, 2001 11:19 AM
