Help Troubleshoot MIL code
Old Apr 4, 2002 | 04:34 PM
LuDeS's Avatar
New User
Default Help Troubleshoot MIL code
I was driving and my prelude threw a check engine light and the atts light came on... I checked the MIL codes and it was a 7... Which is the code for the Throttle Control/Position Sensor... Now what does that mean???? Whats wrong with my car???? It drives fine there is no noticeable difference in throttle response... What is wrong someone please help...
Old Apr 4, 2002 | 04:39 PM
LuDeS's Avatar
New User
Default Re: Help Troubleshoot MIL code (LuDeS)
Ok Correction it was 7 long lights... So its a cat failure i guess... What should i do to check exactly whats wrong?
Old Apr 4, 2002 | 04:41 PM
EP3_05's Avatar
If it is 7 long lights and the cat has failed. Locate the catalytic converter on your car and take it out of the exhaust path and inspect it. See if it has clogged. Just some thoughts. I am not too familiar with the exhaust setup on the newer preludes.
Old Apr 5, 2002 | 01:07 AM
Perfectionist's Avatar
The second O2 sensor (after the cat) is not acting as it should because either the sensor is whacked or the cat is not cleaning up the exhaust. Check out the sensor first.
Old Apr 5, 2002 | 02:55 AM
EE_Chris's Avatar
Default Re: Help Troubleshoot MIL code (Perfectionist)
Agreed...check out the sensor first.
It should read about .6-.8V while cruising along. On decel, it should go totally lean, which is about .1V or less.
It should NOT mirror the response of the primary O2, meaning, it should not be swinging around as the primary O2 does. If it is, the Cat is not functioning as it should.
Old Apr 5, 2002 | 04:53 AM
LuDeS's Avatar
New User
Default Re: Help Troubleshoot MIL code (EE_Chris)
Hmmm... can a cat failure do any major damage to my car if i dont get it fixed right away? and another thing that might help figure out the problem.. whenever i REALLY get on the throttle i get this fuel smell in the car that i never had before...
Someone help please...
Old Apr 5, 2002 | 09:57 AM
88_SC_CRX_Si's Avatar
New User
Go over your fuel system and injectors, for any kind of residue left from gas. It's usually a browinsh color, around the injectors. Otherwise, have a look at your fuel pressure regulator. I am more inclined to think it's a leak at high pressure tho....
Just my thoughts...
94 IntegraLS
Oct 4, 2010 05:38 AM
bma1818
11
Apr 20, 2006 02:11 PM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
halfNhalf-83
Nov 20, 2003 11:12 PM
Crossett
Dec 24, 2001 07:08 PM
