more dumb questions about parts that i dont know. . .
Old Apr 4, 2006 | 11:25 AM
.kyle's Avatar
Default more dumb questions about parts that i dont know. . .
well you guys helped me out right away yesterday with my questions. . but today i have more. . . sorry. . .well anyways . .
(2nd picture)i know this is an oil feed line but i was wondering if that top picture is an oil feed line then are there two. . ? im really dumb , i just need some help!
THANKS!
Old Apr 4, 2006 | 11:27 AM
dpetro1's Avatar
Default Re: more dumb questions about parts that i dont know. . . (IWantATurbo)
top is oil feed...bottom is just a tap into the compressor housing that you could use to hook up your wastegate.
Old Apr 4, 2006 | 11:29 AM
.kyle's Avatar
Default Re: more dumb questions about parts that i dont know. . . (dpetro1)
alright cool thanks!!! that helped me out a lot. . i was a little stumped. . . THANKS! but if i hook my wastegate up to that bottom picture where can the vaccuum lines hook up?
Old Apr 4, 2006 | 11:36 AM
DJ Gurgla GSR's Avatar
you can run the wastegate vacuum line directly to the turbo (like in the second pic), or you can run a vac line from another source (like the brake booster line) to the wastegate
tapping from the intake manifold (brake booster) as opposed to the turbo, gives you a more accurate boost control cuz the turbo reflects the pressure BEFORE the pressure drop in the intercooler
Old Apr 4, 2006 | 11:38 AM
.kyle's Avatar
Default Re: more dumb questions about parts that i dont know. . . (DJ Gurgla GSR)
so i dont have to put anything on that second picture tap then . . . it can just be like that!?
Old Apr 4, 2006 | 11:44 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWantATurbo &raquo;</TD></TR><TR><TD CLASS="quote"> but if i hook my wastegate up to that bottom picture where can the vaccuum lines hook up?</TD></TR></TABLE>
wastegates dont actually use vacuum, they use boost. so that nipple reads the boost right fom the compressor itself. as mentioned above, you can hook up the side port of the wastegate to the compressor hosuing or to any vacuum source (IM, brake booster, etc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Gurgla GSR &raquo;</TD></TR><TR><TD CLASS="quote">
tapping from the intake manifold (brake booster) as opposed to the turbo, gives you a more accurate boost control cuz the turbo reflects the pressure BEFORE the pressure drop in the intercooler</TD></TR></TABLE>
i prefer to run the wastegate fom the IM as well, but there are some that will argue that using the compressor housing is better. i forget why but i guess as long as you are reaching the proper boost level and its consistent than everything is good to go.
Old Apr 4, 2006 | 11:45 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWantATurbo &raquo;</TD></TR><TR><TD CLASS="quote">so i dont have to put anything on that second picture tap then . . . it can just be like that!? </TD></TR></TABLE>
if you arent going to use that nipple for the wastegate then you will need to plug it. so either cap it or take it out and plug it. it should be 1/8 npt thread.
descartesfool
May 10, 2008 08:22 AM
Hondatuner88
Mar 7, 2008 03:15 PM
teddy_dc2
Aug 8, 2006 07:34 PM
nekkedR
Jan 24, 2004 11:32 AM
dualknuttz1
Aug 10, 2003 10:34 PM
