welding oil pan on veichle...?
Old Apr 4, 2006 | 09:40 AM
HamiltonRex's Avatar
Default welding oil pan on veichle...?
Well, the other day i welded on my oil return bung into my pan, and sadly it seems to be leaking.. (backed off fitting a bit and threads were dry), and it looks like its comming from the weld. But i am new to welding so its all good.
Now.. i didnt fill it with oil till today, and ive got EVERYTHING else back together.. way to much work to pull it again.
Im thinking of just backing off the return line fitting, and giving it another pass with my mig.. the oil is drained ofcourse..?
Am i good to go?
EDIT: Others have told me to clean it up, and give it a coating of JB weld, i would rather not do this
Old Apr 4, 2006 | 09:49 AM
ManBearPig4silly's Avatar
Red hot steel + oil.........hmmmmmmmmmmmmm
maybe not?
Old Apr 4, 2006 | 11:12 AM
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">Red hot steel + oil.........hmmmmmmmmmmmmm
maybe not?</TD></TR></TABLE>
I drained the oil, and i only welded a very little bit at a time.. It didnt get all that hot, everywhere, just in the direct area i was welding.
Came out much better this time, i used a 0.035 mild steel wire vs the 0.023 stainless wire i used before... (it was in the machine) much better penetration.
Should i use teflon tape on the fittings?
Old Apr 4, 2006 | 11:24 AM
00TurboEX's Avatar
Default Re: (HamiltonRex)
yes
Old Apr 4, 2006 | 12:45 PM
Default Re: (00TurboEX)
well.. filled it back up with oil and success! No leak.
Its good to go
Old Apr 4, 2006 | 01:52 PM
You sir are my hero.
skiwithcars
Welding / Fabrication
Jun 29, 2006 01:38 PM
SM00TH976
May 17, 2006 08:59 AM
Novtecdohc
Aug 31, 2005 04:29 PM
swlabhot
Sep 27, 2004 03:06 PM
Steve91
May 29, 2003 08:43 AM
