lug nut bolt stripped
Old Apr 3, 2006 | 06:03 PM
skata89's Avatar
Default lug nut bolt stripped
Hey guys. I unfornatly have a stripped lug nut bolt. Has anyone ever replaced them and how do you do it? Ive search and found nothing on this. Any info is great.
Old Apr 3, 2006 | 06:08 PM
StolenTeg's Avatar
Default Re: lug nut bolt stripped (skata89)
Hammer a 1 size smaller socket on there and use an impact wrench on it, it that doesnt work maybe vice grip socket can.
I stripped one of mine nut too and i end up using a drill and drill the damn stud, it work
IHTFP's Avatar
its been discussed before..
but if youre talking a stripped stud, if its not too bad you can rethread them yourself w/ a tap and die kit..
but its FUBAR, then you can replace it yourself..it involves taking the rotor off and using an impact gun to pull the new stud through the hub..
my advice to you is to drive carefully to a tire shop and have them replace it..it shouldnt be too much
edit: or did you strip the actual lugnut and its stuck on the stud and you cant take it off???
Old Apr 3, 2006 | 06:14 PM
skata89's Avatar
Na I cant rethread it. Its really bad. Is there a way i can pull the whole wheel hub off because its on stands for the moment.
akces
Sep 27, 2008 03:12 PM
masijdm
May 22, 2008 10:35 PM
roundworldsobig
Sep 1, 2006 08:08 AM
BlendedEJ8
Jul 28, 2003 08:29 PM
Joe
Oct 14, 2001 11:27 AM
