integra tire/bolt problem
Old May 22, 2008 | 08:37 PM
masijdm's Avatar
Default integra tire/bolt problem
i broke one bolt do you guys think, its safe to drive? & what do you call the whole thing so i can replace it. Any ideas? thanks!
<br/>
Old May 22, 2008 | 08:46 PM
toyomatt84's Avatar
Sanji
Default FV-QR
Lug stud.
Old May 22, 2008 | 09:56 PM
dude_123's Avatar
Default Re: integra tire/bolt problem (masijdm)
Which wheel stud did you broke? The fronts or the rears? If it's the one on the rear all you have to do is rotate the hub until there is enough space in the rear of the hub to hit out the broken stud.
Then just put in the replacement stud in and use an open end steel lug nut to pull out the replacement one. Remember to lube the threads with antiseize, grease, or oil before pulling out the replacement stud with the open end nut to avoid cross/stripped treads.
By the way you can buy replacement stud at any automotive parts store.
If you broke the front then special tool is needed and probably putting a new wheel bearing in is not a bad idea.
Old May 22, 2008 | 10:35 PM
masijdm's Avatar
Default Re: integra tire/bolt problem (dude_123)
thanks alot! guys yes its the front once i think its more harder! than ill just give it to a mechanic:? maybe
Elvis Gaytan
Aug 13, 2013 03:29 PM
snzh22
Jul 31, 2008 09:52 AM
skata89
Apr 3, 2006 06:14 PM
bbrian
Aug 6, 2005 06:09 AM
Joe
Oct 14, 2001 11:27 AM
