CEL Six wont go away!!!!!!
Old Apr 3, 2006 | 05:01 PM
THEUSED's Avatar
Default CEL Six wont go away!!!!!!
Im throwing cel code 6 (engine coolant temperature sensor) so I replaced the sensor and I went to check the code using my stock cx ecu and its gone, but when I put any of my two chipped p28s in its trips the code again, I cant handle this I swear im just going to sell my car and be done with it
Old Apr 4, 2006 | 05:24 AM
THEUSED's Avatar
Help
Old Apr 4, 2006 | 11:33 AM
91' LS-VTEC's Avatar
Default Re: (THEUSED)
I just did a HG on my B16 and now I'm getting a Code 6 also.
That and now my car won't turn over
Bump for answers on Code6!
Old Apr 4, 2006 | 01:31 PM
Relic1's Avatar
follow every step on here and you will find your problem.
http://www.b18c5eg.com/images/EG_11-65.jpg
http://www.b18c5eg.com/images/EG_11-66.jpg
(ECU reset is basically remove battery ground for a few minutes, same as pulling the ECU)
Old Apr 4, 2006 | 05:05 PM
THEUSED's Avatar
Default Re: (Relic1)
Thanks but I have Helms Manual
Old Apr 4, 2006 | 05:44 PM
rainforest's Avatar
so did you check it if you have a helms? whats wrong then?
Old Apr 4, 2006 | 09:12 PM
THEUSED's Avatar
Of course I checked the helms, hell I replaced the sensor all together but the code keeps getting thrown when I use a p28 but not my p05 CX ecu... which is the issue
Old Apr 5, 2006 | 07:50 AM
Relic1's Avatar
you checked the Helm, did you go through the entire procedure step-by-step to check for wiring posibilities? (the reason I posted it)
the P05 and P28 should check for the ECT sensor the same, all though you may have an intermittent open issue that only shows itself when you swap ECUs.
Have you tried the P28s in someone elses car? Your P28s could simply have issues with your car. (electrically, not anything personal)
do the P28s pop the code right away when you switch on the ignition or after a little bit of driving?
what about the P05?
Old Apr 5, 2006 | 10:44 AM
THEUSED's Avatar
They pop right away with the p28, I havent even started the car near a month now
Old Apr 5, 2006 | 02:25 PM
Relic1's Avatar
Just to state it here.... like suggested on PGMFI, do the P28s pop the code with J1 removed?
Old Apr 5, 2006 | 08:00 PM
THEUSED's Avatar
The p28 with j1 cut trips it, and when I go to reset the ecu it keeps throwing the code as soon as I turn the key to the on position
Old Apr 6, 2006 | 12:36 PM
Relic1's Avatar
this is really strange since the P05 and P28 should be internally identical on this circuit.
Have you tried the P28 on a different car?
just a thought... you may have a wiring issue that the P28s are pointing out and your P05 is broken.
Old Apr 7, 2006 | 09:21 AM
THEUSED's Avatar
I had blown my cooling fan fuse back when everthing first happened and have since replaced it, but maybe a wire got shorted or something.... were going over wiring in school right now so ill go at it with the multimeter here really soon....
Old Apr 17, 2006 | 08:05 PM
THEUSED's Avatar
I used a multimeter on the ECT connector and it came up 5v so thats good, I checked pins in the harness to the ecu and they looked fine, Im out of ideas
Old Apr 17, 2006 | 09:22 PM
Relic1's Avatar
ground connection maybe???
Old Apr 18, 2006 | 05:08 AM
THEUSED's Avatar
The sensor's plug is getting voltage so its grounded... what other grounds should
I check?
Old Apr 18, 2006 | 07:42 AM
Will driving with a code 6, effect the performance of the car. or cause any damage to the motor?
Old Apr 18, 2006 | 09:56 AM
THEUSED's Avatar
No, it just puts my car in limp mode
Old Apr 18, 2006 | 12:21 PM
suckawillis's Avatar
hey, just an idea, the ect plug and vtec oil pressure switch are right next to eachother, and they both plug in the same(same plug)and if you plug them wrong, the cel code 6 will come on. try switching the two plugs. I went through like 3 ect sensors before noticing that i switched the plugs lol
Old Apr 18, 2006 | 08:45 PM
Default Re: (suckawillis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">try switching the two plugs.</TD></TR></TABLE>
lol...that took care of my problem.
Old Apr 19, 2006 | 08:42 AM
Default Re: (91' LS-VTEC)
lol gets ya every time
Old Apr 19, 2006 | 05:30 PM
THEUSED's Avatar
You retard lol, I think ive narrowed it down to my Hondata Blue Box, now if Hondata would just reply to my emails.....
Old Apr 20, 2006 | 06:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">You retard lol, I think ive narrowed it down to my Hondata Blue Box, now if Hondata would just reply to my emails..... </TD></TR></TABLE>
Good luck with your ECU. Its got to be something simple.
Old Apr 24, 2006 | 09:13 AM
THEUSED's Avatar
I recently got a new header and exhaust so I figured I start my car to see how they sound, and to my surprise Code 4 (crank position sensor) pops so after some research I find that sometimes code 4 can somehow trip as a code 6 or something weird like that anyways looks like I need a new dizzy... and also a job
jetblack
May 16, 2006 06:20 PM
THEUSED
10
Apr 26, 2006 12:50 PM
progress
Apr 14, 2005 01:09 PM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
arw321
Jan 22, 2004 08:33 AM
