Where do Arias piston rings go?
Old Mar 4, 2006 | 12:13 PM
crex23's Avatar
Default Where do Arias piston rings go?
I know the two skinny rings and the gold oil ring go together on bottom, but I'm unsure about the other two. They both look the same in size, but one has a black edge with red and yellow tips, the other is silver with a yellow tip.
Thanks for the help
Old Apr 23, 2006 | 10:53 AM
2 0 3's Avatar
Default Re: Where do Arias piston rings go? (crex23)
yellow is 2nd compression ring, red is top compression ring
Old Apr 23, 2006 | 12:57 PM
Chiovnidca's Avatar
Default Re: Where do Arias piston rings go? (on_motor_only)
gotta make sure they're not upside down also.
Old Apr 23, 2006 | 07:34 PM
WhiteNess's Avatar
Default Re: Where do Arias piston rings go? (Chiovnidca)
ummm....do you have to file these down guys?????
Old Apr 24, 2006 | 10:37 AM
msmotorsports's Avatar
Default Re: Where do Arias piston rings go? (WhiteNess)
You'll definitely need to file down and get the proper gap for your bore size.
tobster
Jan 22, 2010 05:10 PM
Balmoral
Oct 29, 2008 08:08 PM
vtec dub
Aug 3, 2007 03:39 PM
LSVtechnologytur...
Feb 6, 2005 09:07 AM
Dyno Queen
Aug 26, 2003 08:17 PM
