B series or Dseries turbo
I got a D16y8 in my civic. im just wondering whether i could make more power outa a B or H series or swap or a turbo on my current engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Just turbo your y8, it will be fun and cheap and you'll still have money left over. </TD></TR></TABLE>
QFT
QFT
The turbo d will be faster than the b or h out of the box. If your d series has a lot of miles you might reconsider. Thats one reason I didn't boost my d series (that and my aem cam gear smoked my head), so then maybe you should go with the b series motor. You'll have more money later down the road to boost that and then you'll be fasterest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek »</TD></TR><TR><TD CLASS="quote"> you'll be fasterest.</TD></TR></TABLE>
fasterest?? haha
boost the D ..
fasterest?? haha
boost the D ..
Bump
i'm also considering this. i have a jdm d16a(usdmd16z6) with around 40k on it. when is "too much milage" considered for turbo.
if i swaped, i'm planning to go b18c. budget is 3.5k but saving money is always a good thing
he speaks the truth, i had a blast in my turbo D back when i had it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">Bump
I'll let you know when it's "too much mileage". I'm currently at 230k on my stock D16Z6. It's been turbo'd since last summer. I was running 7-10psi with zero problems, but recently I've been running 15psi on a TD04 14G (small) turbo.
I'm burning a good bit of oil, which I think is a combination of blown turbo and blown piston rings (rings are most likely gone because my VAC portion of my tune is too rich.)
</TD></TR></TABLE>I'll let you know when it's "too much mileage". I'm currently at 230k on my stock D16Z6. It's been turbo'd since last summer. I was running 7-10psi with zero problems, but recently I've been running 15psi on a TD04 14G (small) turbo.
I have had both and honestly I perfer B series. I had a lot of fun with the turbo D16 but in the end it cost to much to get more out of it. After I sold it i got a B20 turbo, full swap with a T3/T4 was only about 2 grand. Never went vtec with, didn't need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sir_Wallace »</TD></TR><TR><TD CLASS="quote"> Never went vtec with, didn't need it.</TD></TR></TABLE>
oh....but want and need are two different things my friend
