Blown head gasket?
Old Apr 2, 2006 | 03:56 PM
allmotorsi04's Avatar
Default Blown head gasket?
Well i have been on here trying to figure out what could be the problem with my car having low compression and making low numbers on the dyno......check this out...i was going through the car after running another compression test and also just checking for some boost leaks when i cleaned up around the head and found this.....fluid leaking from the head gasket or what i believe is coming from the headgasket......what do you think?
Old Apr 2, 2006 | 04:01 PM
non-VTEC's Avatar
Default Re: Blown head gasket? (allmotorsi04)
looks like the oil is leaking down to the headgasket area.......have a look at your valve cover gasket or cam seal.
i dont think your headgasket is leaking.
Old Apr 2, 2006 | 04:03 PM
Default Re: Blown head gasket? (non-VTEC)
cam seal is fine.......if you clean around the head it starts to leak out again......
Old Apr 2, 2006 | 04:13 PM
TurboCoop's Avatar
Thats probly it then, change it its easy.
Old Apr 2, 2006 | 04:17 PM
I Have an STD's Avatar
wrenchin'
yeah, that looks like EVERY b series motor ive ever seen. they all leak a little bit right there. there is nothing wrong with the head gasket. if it was blown, you would be pressurizing your cooling system under boost and the thing would overheat like MAD.
if it was the head gasket, you would overheat after a hard boost run, like a 3rd gear pull. the car would be fine, then about 10 seconds after the pull your coolant temp guage would shoot up to hot till u relieved the pressure.
Old Apr 2, 2006 | 05:06 PM
blackeg's Avatar
Default Re: Blown head gasket? (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">yeah, that looks like EVERY b series motor ive ever seen. they all leak a little bit right there. .</TD></TR></TABLE>
yea i agree, all mine leak right there. if its a vtec motor, especially an old jdm b16, the vtec solenoid gaskets might be leaking a lil, mine was
Old Apr 2, 2006 | 05:47 PM
mrbsponge's Avatar
no doubt, mine has a tiny bit of oil right theere every now and then
usually comes from old cam seal, or Distributor seal, then it just runs down and forward.
you would know if you had a headgasket problem john, your motor would run like ***, you oil would have coolant in it, your car would run HOT, and you definetley wouldnt be boosting it
i told you what to do and how to solve the issues
i tuned a sohc, with a pieced together kit this weekend and it made 174...........
and a gsR all motor, with bolt ons, 173..........
listen to my old ***
Old Apr 2, 2006 | 06:50 PM
HamiltonRex's Avatar
Default Re: (mrbsponge)
mine used to have oil there.. and it would run down the front of the block..
Leak was from the bottom of the Vtec solenoid.
Old Apr 3, 2006 | 06:24 PM
crazy_eddy's Avatar
i have the same problem leaking from right there all my gaskets are new just rebuild the engine its a B18C6 its boosted. its not the cam seal for sure have the STR cam seal. So you guys are sure i should leave the head gasket alone?
Old Apr 3, 2006 | 07:05 PM
V8_HUNTER's Avatar
id change it to be safe
Old Apr 3, 2006 | 07:36 PM
infrontofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">
jdmitrdc2
Apr 15, 2009 11:31 AM
boostedjdmdc2
Jan 13, 2009 10:49 AM
fluk3d
Jun 14, 2007 11:46 AM
gsrHB
May 4, 2007 03:38 PM
kevinoneill
Sep 17, 2003 05:13 AM
