[B]Starter?[/B]
Old Apr 1, 2006 | 04:06 PM
wreckedhatch's Avatar
Default Starter?
Let me just start off by saying that ive already searched about my problem and there seemed to be many diff possible cases of what can be wrong so i thought i would describe my situation.
Ok, well it finally stopped raining here in the bay, so i decided to take my 92 hatch out, but when trying to start it, it would just almost start but eventually it just started clicking like crazy. Some little kid came over and said it sounded like my car had machine guns, lol. Would this be symptoms of a bad starter? Also someone told me that a bad starter could result in your car dying at like stop lights when driving, is this true because its happened to me before I already tested my alternator at autozone twice and it came back good so we can rule that out. And i cleaned the ground on the starter or by it, and checked the battery connections and other ground on the valve cover to rad support. Any help or suggestions is appreciated
Old Apr 1, 2006 | 04:08 PM
btleier's Avatar
I would have your battery tested as well. A starter wouldn't cause your car to die at stoplights and such.
Old Apr 1, 2006 | 04:17 PM
ilu's Avatar
ilu
Default Re: (btleier)
more details on when it died at lights, how, how often, etc......
Old Apr 1, 2006 | 04:19 PM
Default Re: (ilu)
my bad, it only died once and that was when i was mashing my car and came to a stop quickly, and it died. but i noticed that every once in a while while at a light my car seems to loose power, like it sputters until i hit the gas. Its funny because when i told my brother this he took it out for a drive several times and it was fine.
But right now, my car wont even start, it just clicks like a "machine gun" as my little neighbor told me, i thought that was hella funny! lol.
Old Apr 2, 2006 | 10:49 AM
Default Re: Starter? (wreckedhatch)
ttt
Old Apr 2, 2006 | 10:53 AM
92hatchling's Avatar
i would say its you battery
Old Apr 3, 2006 | 06:44 AM
Default Re: Starter? (92hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchling &raquo;</TD></TR><TR><TD CLASS="quote">i would say its you battery</TD></TR></TABLE>
thanx , i'll go and get it checked out today, but for the mean time anybody wanna confirm?
Old Apr 3, 2006 | 06:54 AM
db8gsr_teg's Avatar
my 4dr gsr was doing the same clicking and i just change it yesterday with a b16 starter and it start up like a b16, no more clicking. So change your starter then its all good
Old Apr 3, 2006 | 09:14 AM
Default Re: (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">my 4dr gsr was doing the same clicking and i just change it yesterday with a b16 starter and it start up like a b16, no more clicking. So change your starter then its all good</TD></TR></TABLE>
thanx for the help homie When it stops raining i'll try it out.
Old Apr 3, 2006 | 10:12 AM
FalkenSiR's Avatar
Default Re: (wreckedhatch)
Starter relay?
Old Apr 3, 2006 | 11:18 AM
Default Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Starter relay? </TD></TR></TABLE>
thanx, how do i check that?
Old Apr 3, 2006 | 12:00 PM
someone just told me it might be my voltage regulator, but could that be the problem even though my alternator passed at autozone?
Old Apr 3, 2006 | 03:59 PM
btleier's Avatar
we can throw out a million ideas... but you need to start eliminating some things... you had the alternator checked, have the battery checked next... if that doesn't work, try a starter...
Old Apr 5, 2006 | 04:53 PM
haha... i guess it was my battery because i had it checked and it was no good so i put a new one in and it started up like no other! Just wanted to say thanx guys for the help. All this time i thought it was something more complicated
Old Jun 19, 2006 | 06:27 AM
imadigitalgod's Avatar
u always want to eliminate the most simple things like the battery first(that turned out to be the problem in the first place). I know someone that the first thing that he did when her car didnt start was change the alternator , the starter and THEN tested the battery after all that didnt work.
glad to hear it was a simple fix
ATS*Mark
Oct 5, 2019 05:01 AM
D7KWagon
Aug 8, 2014 02:57 AM
PuiPui
May 5, 2005 03:27 PM
RCautoworks
Jan 17, 2003 10:19 PM
ls_vtec_b18a1
Nov 4, 2002 07:12 PM
