Hide'n my Synchros problem.
Old Apr 1, 2006 | 11:00 AM
JDM B16A's Avatar
Default Hide'n my Synchros problem.
So, my 3rd and 5th gears are grinding as i shift into them. The 3rd one only grinds at over 4.7 RPM. while the 5th grinds at ANY rpm when i shift into it. I am plan'n on covering it upwith PENNZOIL SYNCHROMESH. How many qts should i use for my JDM B16A first gen in an EM1? And do you guy think PENNZOIL SYNCHROMESH are the best choice to cover it up untill i get it repair? BTW I have hydraulic tranny.
Old Apr 1, 2006 | 11:42 AM
JDM B16A's Avatar
BUMP! Please help!
Old Apr 1, 2006 | 11:46 AM
coconutsoldier's Avatar
Default Re: (JDM B16A)
I wouldn't use anything from pennzoil. They are one of the shittiest oils available.
I would just try a thicker oil, and if that doesn't help, the synchros will probably need to be replaced.
Old Apr 1, 2006 | 12:19 PM
junkyardd16z6's Avatar
Default Re: (coconutsoldier)
Theres really no way to hide em when they start goin, I would go to a GM dealership and get thier synchromesh formula, when my turbo single cam started gridin gears I used it and cleared it up for about 1500 miles or so but...it started again soon afterword.
Old Apr 1, 2006 | 12:49 PM
E46Kid's Avatar
bump cuz i have the same problem!
Old Apr 1, 2006 | 12:54 PM
JDM B16A's Avatar
BUMP!!! SOME HLEP FOR US PLEASE!!
Old Apr 1, 2006 | 08:11 PM
93Civac's Avatar
I had a grind going into third, I used the GM syncromesh friction modified fluid and now the only time it grinds is under full throttle shifts. It doesnt do it everytime like before. I think it should take a little over two quarts, I dont remember though.
Old Apr 1, 2006 | 09:06 PM
Kevinarich's Avatar
when you say "cover up" does that mean just untill you sell it? cuz thats not cool, but a good way is saw dust, or is that for an auto?
Old Apr 1, 2006 | 09:20 PM
Cuda70's Avatar
Default Re: (Kevinarich)
Saw dust is for an auto... How do I know?
When I was 18 I bought a (Fairly new) '74 Chevy Nova from a guy. The tranny went out in it 2 weeks later. It was filled with saw dust. Needless to say, I was not impressed!
Old Apr 1, 2006 | 09:27 PM
aspec101's Avatar
Default Re: (Cuda70)
yeah if you are trying to cover up a problem to sell it, well I hope the buyer whoops your *** once they find out what you did. By the way your title says it sounds just like that. If not they why not just fix your problem instead of trying to "hide" it. Whats the point?
Old Apr 1, 2006 | 09:43 PM
erasable180's Avatar
i just put in some ac delco synchromesh in my trans and i really havent noticed a difference, still grinds some times
Old Apr 1, 2006 | 10:39 PM
BALLIN H22 EK's Avatar
Default Re: (erasable180)
i think veggie oil will fix it
Old Apr 2, 2006 | 12:08 AM
JDMC-Kamel's Avatar
Default Re: (BALLIN H22 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK &raquo;</TD></TR><TR><TD CLASS="quote">i think veggie oil will fix it </TD></TR></TABLE>
might as well work if your trying to cover it upLOL
Old Apr 2, 2006 | 07:44 AM
92civichatch1's Avatar
Default Re: (JDMC-Kamel)
well..
1. pennzoil synchromesh is not crappy. i got it in my gsr and its all good.
2. and my CX trans took 2 qts and my gsr tranny takes~3qts
Old Apr 2, 2006 | 07:58 AM
BauleyCivic's Avatar
Risky Business
Default Re: (92civichatch1)
Synchromesh (Pennzoil or GM) masks the problem by delaying the shifts. The gears are harder to get into, so it puts less stress on the synchros. I was unimpressed with the synchromesh when I got it, but I know some people swear by the stuff. There is no "quick fix" to a grinding tranny other than to get the synchros replaced. Sorry
Old Apr 3, 2006 | 08:56 AM
EKlscoupe_98's Avatar
Default Re: Hide'n my Synchros problem. (JDM B16A)
i have the same problem how chaep is it to replace synchros
Old Apr 3, 2006 | 12:34 PM
JDM B16A's Avatar
You dumb *** need to stop assume'n things. I am not covering it up to sell the car. I just want it not to gridn untill i get it repair. So dont' assume stuff you do'nt know about.
alex_belarus
Nov 22, 2007 01:40 PM
TH33G4MON3
13
Mar 23, 2006 10:59 AM
JDM B16A
11
Mar 18, 2006 03:44 PM
preludesi2188
Nov 28, 2005 07:08 AM
flatblk
Aug 15, 2005 02:57 PM
