Honda Quoted me $165 for wheel studs, is it worth it?
Old Apr 1, 2006 | 09:55 AM
silentblackhat's Avatar
Default Honda Quoted me $165 for wheel studs, is it worth it?
I went to honda today to ask them how much it would be to replace a wheel stud that broke and they said about $115 for parts and labor. I asked how much for all of them replaced and they said about $50 more for the other ones to be put in. I am wondering is it worth having them do it or are there other shops that will press the hub out to change the wheel studs?
any info is helpful
Old Apr 1, 2006 | 09:57 AM
D16z6BoostedEK's Avatar
how many wheels studs do u need i can get them for u for a cheaper price!
Old Apr 1, 2006 | 09:58 AM
hondapowa's Avatar
Default Re: Honda Quoted me $165 for wheel studs, is it worth it? (silentblackhat)
Replace them yourself, cheaper and much easier than you think!
Old Apr 1, 2006 | 10:00 AM
slo97coupe's Avatar
wow, wheel stud at advanced is like $2.48
just do it your self and buy me dinner!!
Old Apr 1, 2006 | 10:29 AM
Default Re: (slo97coupe)
the thing is i dont have a press to do it with. i have 4 studs that i got for $1.67 each. i know people say there are ways without a press but idk how to do that. can anyone tell me how or have any info on the way without a press?
Old Apr 1, 2006 | 10:35 AM
kaoss_11's Avatar
B A N N E D
get arp studs
Old Apr 1, 2006 | 10:40 AM
nightrider's Avatar
you should search. all i searched for was "wheel stud".
https://honda-tech.com/zerothread?id=907985
Old Apr 1, 2006 | 10:47 AM
jonny_sin's Avatar
all u got to do is hammer them out. to put new ones in all u have to do is get a couple of washers and then the nut after that just run them in til they are nice and tight in there. should.t take u long. takes longer to take the tire offf than the the time it takes to replace the studs in my opinion.
Old Apr 1, 2006 | 10:57 AM
Default Re: Honda Quoted me $165 for wheel studs, is it worth it? (jonny_sin)
how will they pop out if they dont have any clearance behind it?
Old Apr 1, 2006 | 11:12 AM
A.E Motoring's Avatar
Default Re: Honda Quoted me $165 for wheel studs, is it worth it? (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">you should search. all i searched for was "wheel stud".
https://honda-tech.com/zerothread?id=907985</TD></TR></TABLE>
tells u how to do it right here, u can rent those parts at your local auto parts store, all u do is hammer them out, i have seen it done before, very simple process
Old Apr 1, 2006 | 11:24 AM
jdmjaser's Avatar
Default Re: Honda Quoted me $165 for wheel studs, is it worth it? (SPNFEDEH)
jus get arp wheel studs!!
Old Apr 1, 2006 | 11:52 AM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat &raquo;</TD></TR><TR><TD CLASS="quote">how will they pop out if they dont have any clearance behind it?
start off by looking at the thread i directed you towards. obviously, there won't be clearance issues because of the necessary steps to remove the wheel studs.
Old Apr 1, 2006 | 11:59 AM
schardbody's Avatar
take it to a brake or tire shop, at my shop we charge $25 per wheel (no matter how many on that wheel are broke, plus parts. usually runs aroun $35 parts, tax, labor.
Old Apr 1, 2006 | 06:49 PM
Default Re: (schardbody)
Alright ill take a look at the thread and then get back to u guys how it went. sorry i didnt look at it earlier, i was just finishing up my timing belt job(belt, tensioner, waterpump...) b4 i went to work. thanks for the direction tho
Right now i have 4 stock style studs for my car that i got from AdvanceAutoParts. Are they just as good as ones I would get from Honda or would it be better to get OEM studs?
Modified by silentblackhat at 8:08 PM 4/1/2006
Old Apr 1, 2006 | 08:58 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Good link.
Is this in the FAQ archive? It should be.
Old Apr 3, 2006 | 01:25 PM
boost'd_crx's Avatar
parts are cheap. just take the spinde off of the hub and put in the new ones, repack the bearing and hammer back in.
Old Apr 3, 2006 | 01:53 PM
hondapowa's Avatar
Default Re: (silentblackhat)
Modified by silentblackhat at 8:08 PM 4/1/2006</TD></TR></TABLE>
They are no different except the price, and having been made by an aftermarket manufacturer.
743power
182
May 19, 2017 07:30 AM
SlowB16
Jun 11, 2008 07:00 AM
osideracer1
Jun 24, 2005 02:25 PM
