what the hell is this ?
Old Mar 31, 2006 | 11:08 AM
the soL that could's Avatar
Default what the hell is this ?
so i go to wire up my IAB and guess what... A17 has as green wire with a black stripe in there.
i had a p06 automatic ECU before this so i'm guessing it's an automatic wire. not sure but... i need to know what that wire is and where it ends up thanks...
Old Mar 31, 2006 | 11:47 AM
Relic1's Avatar
A17 is the autotrans lockup solinoid valve.
it's also using A19 as the return line.
to save you running the wires through the firewall... driver's shock tower, 14pin connector.
A17 is the green/black wire (pin 13)
A19 is the yellow wire right next to it (pin 14)
Old Mar 31, 2006 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">A17 is the autotrans lockup solinoid valve.
A19 is the yellow wire right next to it (pin 14)</TD></TR></TABLE>
A19 as a return line? meaning? 12 volt power souce?
Old Mar 31, 2006 | 12:57 PM
Relic1's Avatar
neither are connected to a constant 12V or ground connection.
Guessing why this is... the solinoid can be driven open and closed so the two wires need to be switched as far as polarity. much like the door locks.
90_EX_Civic
Mar 21, 2009 07:59 PM
meallout
Oct 20, 2008 08:13 AM
kornerk12
Sep 25, 2007 07:23 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
DevinW
Jul 17, 2003 03:57 AM
