What is this? Random box under dash ..
Old Mar 31, 2006 | 10:06 AM
ella94's Avatar
Default What is this? Random box under dash ..
There is a little black box under the passenger side dash board. Its bolted on with a few screws and it says Honda A/C serial no. on it. What is it used for?
Was mounting some lights under there and the box is really in a bad spot.
If its for the air conditioner, i really dont need it do i? I dont even have a/c on my engine.
thanks
Old Mar 31, 2006 | 10:07 AM
ZacCarter's Avatar
Any wires running into it?
Old Mar 31, 2006 | 10:14 AM
ella94's Avatar
Nope. Only a rubber insulated tube that leads into the dash and maybe the engine bay.
Old Mar 31, 2006 | 10:19 AM
ella94's Avatar
Update: the rubber tube does lead into the engine bay. Its short and it opens out pointing toward the ground, as if it were to drain something. Anyone know what this is before i gank that ****?
Old Mar 31, 2006 | 10:25 AM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (ella94)
maybe dont "gank that ****"
Old Mar 31, 2006 | 10:26 AM
Lewy. Dee Ayy's Avatar
blower motor?
Old Mar 31, 2006 | 10:34 AM
ella94's Avatar
bla useless.
doesnt anyone know what its for? I cant see what the box hooks up to inside the dash but the only thing i can see leading out is that rubber tube.
Old Mar 31, 2006 | 10:43 AM
ZacCarter's Avatar
Take it out, If car does't work right, reverse process. It's called trial and error.
Dear Honda-tech should I wipe my *** forwards or backwards?
Old Mar 31, 2006 | 10:52 AM
-Gary-'s Avatar
Depends. Which way is the grain of the carpet going?
Old Mar 31, 2006 | 11:03 AM
ZacCarter's Avatar
To the east, with a slight wind coming in from the north. Not canadian wind though they are stupid, who needs stupid wind?
Old Mar 31, 2006 | 11:10 AM
Shreik's Avatar
look it up and see what it is... If you still can't figure it out. Post a pic or tell us which part it looks like.
http://www.hondaautomotivepart...h.jsp
Old Mar 31, 2006 | 11:25 AM
Toroke's Avatar
Default Re: (Shreik)
My guess is AC condenser. I just took that out the other day... It's the black box right next to the blower.
Old Mar 31, 2006 | 12:38 PM
Shreik's Avatar
Default Re: (Toroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toroke &raquo;</TD></TR><TR><TD CLASS="quote">My guess is AC condenser. I just took that out the other day... It's the black box right next to the blower.</TD></TR></TABLE>
the condenser is the radiator looking thing in the engine bay on the drivers side. Next to the actual radiator.
The only thing I can think of that has a rubber tube leading down is the evaporator case, which is a big black box. If you don't have a/c and you don't use the fan at all then you can pretty much "gank that ****. while you're at it, might as well take out the blower and heater core if it's there. btw, heater core has coolant lines so you'll have to reroute them and flush your coolant system if you do.
Modified by Shreik at 4:51 PM 3/31/2006
Old Apr 1, 2006 | 11:39 AM
Toroke's Avatar
Old Apr 1, 2006 | 01:18 PM
Syndacate's Avatar
sounds like hte condensor......
Old Apr 1, 2006 | 01:29 PM
SOHC4life 96's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">sounds like hte condensor......</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shreik &raquo;</TD></TR><TR><TD CLASS="quote">the condenser is the radiator looking thing in the engine bay on the drivers side. Next to the actual radiator. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ella94 &raquo;</TD></TR><TR><TD CLASS="quote">bla useless.
doesnt anyone know what its for? I cant see what the box hooks up to inside the dash but the only thing i can see leading out is that rubber tube. </TD></TR></TABLE>
blah, you're the useless one. "I can't figure things out for myself, OH I'LL GO AS H-T!!!!!!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">TDear Honda-tech should I wipe my *** forwards or backwards?</TD></TR></TABLE>
BWHAHAHAHAHA
Old Apr 1, 2006 | 01:36 PM
fwdtamiya's Avatar
Default Re: (SOHC4life 96)
This may seem harsh, but i hope you pull it out and can never get your car to run right again
Old Apr 1, 2006 | 11:55 PM
Shreik's Avatar
y do u guys keep saying condenser?? The condenser is right next to the radiator. The part that goes in the car is called the evaporator.
Old Apr 2, 2006 | 08:47 AM
finch82's Avatar
that would be your evaporator/ blower moter and if you pull it out you won't have a heater any more....
rayrayx11
Oct 14, 2013 05:18 AM
rchid
Jan 19, 2011 11:28 PM
allmotorlscrx
Jan 15, 2009 11:01 AM
92SiB18C1
Nov 15, 2002 09:27 AM
