What is this? Random box under dash ..
There is a little black box under the passenger side dash board. Its bolted on with a few screws and it says Honda A/C serial no. on it. What is it used for?
Was mounting some lights under there and the box is really in a bad spot.
If its for the air conditioner, i really dont need it do i? I dont even have a/c on my engine.
thanks
thanks
Update: the rubber tube does lead into the engine bay. Its short and it opens out pointing toward the ground, as if it were to drain something. Anyone know what this is before i gank that ****?
look it up and see what it is... If you still can't figure it out. Post a pic or tell us which part it looks like.
http://www.hondaautomotivepart...h.jsp
Re: (Toroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toroke »</TD></TR><TR><TD CLASS="quote">My guess is AC condenser. I just took that out the other day... It's the black box right next to the blower.</TD></TR></TABLE>
the condenser is the radiator looking thing in the engine bay on the drivers side. Next to the actual radiator.
The only thing I can think of that has a rubber tube leading down is the evaporator case, which is a big black box. If you don't have a/c and you don't use the fan at all then you can pretty much "gank that ****. while you're at it, might as well take out the blower and heater core if it's there. btw, heater core has coolant lines so you'll have to reroute them and flush your coolant system if you do.
Modified by Shreik at 4:51 PM 3/31/2006
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">sounds like hte condensor......</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shreik »</TD></TR><TR><TD CLASS="quote">the condenser is the radiator looking thing in the engine bay on the drivers side. Next to the actual radiator. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ella94 »</TD></TR><TR><TD CLASS="quote">bla useless.
doesnt anyone know what its for? I cant see what the box hooks up to inside the dash but the only thing i can see leading out is that rubber tube. </TD></TR></TABLE>
blah, you're the useless one. "I can't figure things out for myself, OH I'LL GO AS H-T!!!!!!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter »</TD></TR><TR><TD CLASS="quote">TDear Honda-tech should I wipe my *** forwards or backwards?</TD></TR></TABLE>
BWHAHAHAHAHA
BWHAHAHAHAHA
crls057
03-26-2012 12:18 PM
allmotorlscrx
01-15-2009 11:01 AM
92SiB18C1
11-15-2002 09:27 AM
