suspension?
I got a one question for everyone. I might sound like a "noob" ,but here it goes. I got 94-01 gsr complete front suspension going into my (ek) ej8 with a front sway bar off a 99-00 civic si. Will this all fit properly into my hatch without mods? Gsr front suspension consist of control arms, knuckles, calipers,rotors and brake lines. No axles, tie rod, master cylinder or proportioning valve. If im missing anything let me know. Oh yeah the sway bar is complete too with end links and all. Thanks to everyone who can help me out.
Well, the 99-00 Si front sway bar is not complete unless you have the matching Si LCAs, and damper forks. The damper forks are wider to fit the larger "stamped steel" Si LCA.
If you don't have those parts, you may be able to make it work with the GSR LCAs & stock damper forks (or GSR). The trick will be to see if the GSR sway-bar end-links will attach to the Si sway-bar. Let us know if it works...
PS: To use the larger integra front brakes, your gonna need a larger master cylinder (later integra ones should fit)...
GSR suspension (sway-bar #2):
99-00 Si suspension:
bboygreddy
Dec 5, 2006 09:25 AM
Resident Evo
24
Feb 22, 2005 01:01 PM
