gsr suspension on an ek?
Re: gsr suspension on an ek? (Spoon1)
i have thought about that... but since i have an h22.. i was thinking about trying to go a little thicker than the SI's... if possible that is.. im just curious as to if this works well? or is it even worth the trouble?
[Modified by hondaZvic, 1:21 AM 12/7/2002]
Re: gsr suspension on an ek? (hondaZvic)
Front Sways:
EX-22mm
SI-26mm
For rear sway, ITR (22mm or JDM 23mm) would be great. (don't forget the famous beaks kit).
EX-22mm
SI-26mm
big strong guy
have any of u put the gsr sway bars on ur EKs? if so, is this straight bolt on? or some modification required?
I have not put the GSR bar on front, I had decided to go with somthing a Little Stiffer ie.. Suspension tech, Though I belive it should bolt up?
Make sure you get all endlinks, Bushings, and Brakets for the Sway bar!!
Also for price maybe you should consider getting the Suspension tech Setup!! It made my Ek very Nice!!!
eric
